DLL help
Old Dec 6, 2008 | 11:30 AM
Shacochis06's Avatar
DLL help
im new to DLL so bare with me....everytime i put my log into DLL and do a powergraph the max hp i keep getting is like 250...
i know this aint right i have a fpred it should be over 400hp....somebody please help me i want to get use to DLL and be able to use it....
Old Dec 6, 2008 | 11:51 AM
EvoJoeIX's Avatar
DLL is very inaccurate.. i wouldnt even waste your time
on DLL my car is 490hp and over 500ft lbs of torque. plus its just so easy to manipulate your numbers by changing factors. like weight in car, gear ratios, ect.
i used it once and havent used it since.
Old Dec 6, 2008 | 11:57 AM
it can be accurate if used right...
Mellon has been very succesfull using DLL....i just want to know what i need to do to get it right....
the log only has to be a 3rd gear pull right?
Old Dec 6, 2008 | 11:58 AM
Creamo3's Avatar
I disagree w/ the above in it's inaccuracy; be sure to use the correct car definition, gearing, weight, and make sure the logs you are using are from a road that is straight and not hilly. Factors like wind and hills will throw the numbers off considerably. I have many logs from the same road that are all very consistent w/ each other. Also verify that you are not using SAE correction, unless you're getting updated weather conditions for that log. Let me know if this helps.
Old Dec 6, 2008 | 12:03 PM
im not at all using SAE correction all my logs are correct...flat surface...every log is going in the same direction also....i put the evo VIII 5 speed car definition in since they dont have the IX definitions...i then re did the gear ratios to make them correct like my 5speed...
still no good tho and ive tried many logs....i keep getting a hp reading of no more than 260
Old Dec 6, 2008 | 12:04 PM
and i only log in one spot always going in the same direction so its not like im using a bunch of diffrent logs from diffrent areas
Old Dec 6, 2008 | 12:05 PM
Creamo send me one of your logs to Shacochis06@live.com and let me try to put it in DLL and see what i get or anybody send me your log
Creamo3's Avatar
Can you post a screen shot of your definitions and power map? Maybe you're really only making 260hp It's probably something simple
Old Dec 6, 2008 | 12:12 PM
Creamo3's Avatar
You've got mail
Old Dec 6, 2008 | 12:13 PM
when you put the gear ratios in after 5 it says final whats suppose to be in there
Old Dec 6, 2008 | 12:16 PM
EvoJoeIX's Avatar
the final gear ratio of the transmission....
Old Dec 6, 2008 | 12:17 PM
this is all i keep getting
Old Dec 6, 2008 | 12:18 PM
well whats the final gear ratio for the 5 speeds cos im not using DLL evo 8 definition so i have to put my own in
Old Dec 6, 2008 | 12:21 PM
creamo i really dont think u wanna see yours lol its at like 200 something
i know im probably missing something really lil thats throwing the numbers off complety
Creamo3's Avatar
For 03-05 it was 4.53
