wgdc correction based on MAF IAT
Old Dec 9, 2008 | 10:37 PM
tephra's Avatar
Smile wgdc correction based on MAF IAT
Hi guys,
My next release (V6) will have some fairly basic support for WGDC correction based on the MAF IAT.
Here is a little example:
Basically the number on the right will be added (or subtracted if its negative) to the WGDC out of the base wgdc table.
Now I need some meaningful numbers to put in here, has anyone got any hard facts about temp vs wgdc changes required?
Obviously your 0 correction temp will be the temp at which you tuned your car, but the others around it will need to be modified!
FYI - I want to get V6 out pretty soon, it will mainly be a boost mod patch, ie all my other patches to date plus a bunch of boost modifications.
Hopefully this will end the modifications needed to be done for the boost system, and then I can begin work on other things
Cheers
D.
Old Dec 10, 2008 | 05:08 AM
MR Turco's Avatar
Great stuff tephra! I hope someone has some good logs to show difference. I can *guess* that for around -30*Fchange (~16*C change), tune in 55*F driving in 25*F, you need to remove about 10% WGDC maybe more. I haven't retuned the car for the cold weather so i don't know the change.
Old Dec 10, 2008 | 05:34 AM
dudical26's Avatar
In my experiance 10% would be a bit much. For my setup at least it would probably be closer to 6-8%.
Old Dec 10, 2008 | 05:39 AM
dudical26's Avatar
Also, I find that temp changes matter less and less as you get away from about 50*f The change from 50*f to 30*f is more significant than the change from 30*f to 10*f for example.
Old Dec 10, 2008 | 06:22 AM
MR Turco's Avatar
I agree but at peak torque you may need -10% to avoid high spike where later in the RPM range you may only need 6-8%. I might lean towards being conservative in the winter anyway.
I also agree, it is not linear.
Old Dec 10, 2008 | 06:23 AM
scheides's Avatar
EvoM Moderator
Wonder what'll be more effective, this or mrfred's direct boost mod?
Cool stuff tephra! Any chance on doing gear-dependant boost?
Old Dec 10, 2008 | 06:28 AM
travman's Avatar
This will work hand in hand with mrfreds direct boost mod + gear dependent control.
I had my cars boost set in like mid 50 degree weather and when it dropped into the 30's I had to take out about 5% at peak to stay around 23-24.
Old Dec 10, 2008 | 06:29 AM
jcsbanks's Avatar
Nice. schiedes, I think all three together will be available.
Old Dec 10, 2008 | 08:15 AM
dudical26's Avatar
I use direct boost and I still need to change WGDC with temps. Direct boost makes things easier, but the system is still temp sensitive.
Direct boost + auto temp corrections + individual gear boost = awesome boost control system.
Old Dec 10, 2008 | 08:32 AM
tnt1106's Avatar
I could not agree more! Thanks to Tephra and Mrfred and others for all their hard work!!
Old Dec 10, 2008 | 10:29 AM
mplspilot's Avatar
Neat stuff. It'll get rid of boost overspike in cold weather on first pull when error correction hasn't done it yet and just make it smoother, getting rid of oscillations that spike usually causes.
You'll just need 5-6 months to fully tune it
I personally will still have to reflash my boost adder for winter and summer anyway as i run 2 psi less in winter. No need for too much boost on ice even on snow tires But automating WDGC adjustments would be pretty nice i suppose.
Old Dec 10, 2008 | 11:36 AM
TouringBubble's Avatar
How will this modifier work with the max WGDC correction factors? So, if I had a max correction of +5 over my tuned 50% WGDC, the max WGDC is 55%. If this weather correction kicks in does it lower this max WGDC%?
Old Dec 10, 2008 | 11:38 AM
MR Turco's Avatar
I would think this just offsets the whole table.
Old Dec 10, 2008 | 02:44 PM
tephra's Avatar
yeah this will happen during the WGDC map lookup.
so say you have 80% in the Base WGDC, and you tuned at 30F, and now its 0F, and you have -10 in 0F WGDC/MAF IAT correction table, then you would get 80-10.
70 obviously.
So then the normal ECU corrections would happen.
One thing to note is I have made it happen when WGDC not 100%. So if you are at 100% WGDC and the temp changes then you wont get any temp correction. I figure ppl at 100% WGDC are trying to get as much boost as possible, so correcting it is dumb
This is primarily for overshoot on spool - I am not particularily phased at higher RPM's as the normal TBEC handles this fairly well.
scheides - yes FULL gear based wgdc will be in the next release - its awesome
Old Dec 10, 2008 | 03:11 PM
nonschlont's Avatar
+1,000,000 Thanks to all involved! Very Cool Stuff! Looking forward to the release!
