Need help with Evoscan 2.5
Old Dec 20, 2008 | 11:03 PM
raasfaas's Avatar
For those with the knowledge and experience can you tell me what I did wrong. I added the 2byte mods via the 3D MUT tables outlined by Jack of Trades. I also added 2byte to 1byte load mod by Tephra https://www.evolutionm.net/forums/ec...-load-mod.html
The problem i'm having now is that my loadcalc and the 1byte load dont work, only the 2byte load.
Also, my fuel trim are now off...at WOT from 1st to 4th gear my low and high trims both read 0.1008 to redline but my mid trim reads -1.0758. If I do a 3rd gear pull low and high are still the same but now the mid reads 0.493. I'm running stock injectors.
My last issue is how do I get the maptracer to show above load100?
