94170015 work for all 03-04 Evos?
Old Dec 25, 2008 | 01:43 PM
nj1266's Avatar
Just a quick affirmation. Does the 94170015 rom work for ALL 03-04 Evos? I think it does, but I just need confirmation on this.
Thanks
Old Dec 25, 2008 | 01:58 PM
justboosted02's Avatar
worked for me
0008->0015
Old Dec 25, 2008 | 02:36 PM
draconx's Avatar
yea it does
Old Dec 25, 2008 | 06:49 PM
honki24's Avatar
No, not all
At least not the modified version. I've had certain functions work on a few cars and corrupt one ecu. (Granted that may have just been a bad ECU or wiring or something). 14 and 15 sometimes malfunction when it comes to running on an originally 08 car. More often than not though it works and works very well. Again, I'm only talking about Tephra mod versions.
Old Dec 25, 2008 | 07:19 PM
Slo_crx1's Avatar
I believe is still has to be in the same "family" so to speak, meaning 94170008, 94170014, 94170015. If you have the 0008 rom I know personally you can update, and I'm pretty sure for the 0014 as well.
Old Dec 25, 2008 | 08:49 PM
tephra's Avatar
Honki24 - what problems?
Old Dec 25, 2008 | 08:53 PM
this.
Old Dec 25, 2008 | 08:54 PM
tephra's Avatar
Old Dec 25, 2008 | 10:52 PM
PeteyTurbo's Avatar
I have had it not be able to work on an 04 RS...
Old Dec 25, 2008 | 10:59 PM
tephra's Avatar
if the original romid was 94170008 or 94170014 then running 94170015 should NOT be a problem
Old Dec 26, 2008 | 06:34 AM
todd6027's Avatar
whats a replacement with tephra mods for 88840013
Old Dec 26, 2008 | 07:00 AM
randomevo's Avatar
Replacing a stock 94170008 with the stock 015 version works perfectly.
If tuned just transfer over your timing,fuel and anything else modified.
Old Dec 26, 2008 | 08:22 AM
chrisw's Avatar
Any -03 - 04 ECU that originally came with a ROM ID prefixed with "9417" should work with any ROM that starts with "9417". It is a safe assumption that any ECU can accept a given ROM as long as the first 4 numbers on the original rom and the new rom match.
So like tephra says, it will work.
My Evo came from the factory with verison 94170011 (I think, it's been a while), I downgraded to 94170008 and since then, eventually upgraded to 94170014.
I'll have 94170015 on there with tephra's latest mods once the car is ready for another tune.
Old Dec 26, 2008 | 01:46 PM
honki24's Avatar
These were the different cases I came across (these were originally all 008s)
-Unresponsive to fuel map changing
-No modifications worked and random things stopped working such as ICS
-Crazy knock and poor running
-No start
-Killed ECU
I've flashed hundreds and hundreds of times and successfully roadraced on dozens of maps I've made so it wasn't just user error.
The point here is not that "tephra mods may screw up your ecu", but rather that in my experience, yes there are cases when an upgrade from 008 to 014 or 015 WITH TEPHRA MODS is a no-go. Honestly, it really wasn't a big deal (outside of the dead ECU one... which I really think may have been wiring) because you could just go back to an 008 that worked.
Old Dec 26, 2008 | 08:27 PM
PeteyTurbo's Avatar
94170015 did not work on 96420011 which was stock on a 2004 RS just to clear it up..Flash went through but car did not start..Went back to the stock rom and all was good...Just a heads up.
