evoscan 2.5 w/ vista woes
Old Dec 29, 2008 | 06:12 PM
codgi's Avatar
Originally Posted by travman
ok got it.......it was the administrator thing.
I was going into the main programs screen on the desktop and right clicking then for properties which is just the shortcut. I was changing what I thought is what I needed but then I went into the actual program file folder in the C: drive......I right clicked on the actual evoscan.exe file and there was the run as administrator box to click. I checked the box, program installed and it all worked....well least the opening part (need to test logging)
So codgi thank you for questioning me and making me dig deeper.....so far im not totally hating vista but its def. a little more security unfriendly but I will get used to it....
I will post tomorrow if it logs properly.....I have 2.5 and 2.6 opening without any errors so I will test both for logging and report back.
Well glad that worked out. In general for most Vista related problems for most programs (especially those that were written for older windows) i usually suggest that "run as" option first .
Old Dec 30, 2008 | 05:14 PM
ant_turbo's Avatar
Someone help please...someone help please...someone help please...
Old Dec 31, 2008 | 12:08 AM
ant_turbo's Avatar
BUMP..
Old Jan 1, 2009 | 01:29 AM
ant_turbo's Avatar
E-MAILED LIMITLESS And this is what I got,,
Message:
Hi Mate,
Evoscan v2.6 beta6 supports vista 64bit
EvoScan v2.6 beta6 software is available here
http://www.limitless.co.nz/evoscan/E...Ev2.6beta6.zip
You can go to the folder c:\program files\evoscan\ and make a copy of the "EvoScan v2.5" folder and rename it to "EvoScan v2.6 beta6" and then extract the EvoScanUPGRADEv2.6beta6.zip over the top of the new "EvoScan v2.6 beta6" folder.
Regards,
Hamish Ahern.
http://www.limitless.co.nz/EvoScan
http://www.limitless.co.nz/Cables
Old Jan 1, 2009 | 09:11 AM
travman's Avatar
yes it does work.....
- only problem was I cant get it to communicate with my ZT2, but the rest works fine so far.
Old Jan 1, 2009 | 04:00 PM
ant_turbo's Avatar
Can u give me a run down of what you did to get it to run on VISTA,,
THANKS,,,,
Old Jan 3, 2009 | 05:56 AM
Motoxrider7's Avatar
Same here im trying to tune today and this is the only thing stopping me.
Old Jan 4, 2009 | 01:07 AM
ant_turbo's Avatar
STILL NEED HELP PEOPLE...
Old Jan 4, 2009 | 11:11 AM
evo4mad's Avatar
did you read the instructions on the website about the folder permissions? other than that evoscan v2.6 beta6 works fine on Vista.
Old Jan 4, 2009 | 12:43 PM
ant_turbo's Avatar
Ok so lets stat all over...I uninstalled 2.5 and them reinstalled 2.5 And didn't run evoscan 2.5 to enter my email and serial number,,Then I went to c:\program files\evoscan
Clicked evoscan then I right clicked and copied EvoScan_v2.5 and made a copy in the same folder where EvoScan v2.5 is so now I see are EvoScan v2.5 and EvoScan v2.5_copy Then I rename the copy of EvoScan v2.5_copy To EvoScan v2.6 beta6 Then copy and paste the 3 files that are in the EvoScanUPGRADEv2.6beta6 in the copy of 2.5 That I renamed to EvoScan v2.6 beta6.... I'm I missing something,, Still not logging anything all zeros,,,
I hope I didn't confuse you,,
Old Jan 5, 2009 | 05:17 AM
travman's Avatar
There is only one file for beta6.......I think your doing what I did and copying beta 4 over (thinking its beta 6).
Click the link in the 2.6 thread and copy the exe file into the folder you created and you should be good.
Beta 6 def. does work on 64 bit vista
Old Jan 5, 2009 | 06:53 AM
Jersey Dino's Avatar
I have tried evoscan 2.5 and 2.6 beta on my macbook pro with XP and all works EXCEPT the wideband. it doesnt record anything. I tried to get it to work on a native vista machine and got the same errors you described above. I have not gone into the folder permissions yet but I will try it and see if I can get the wide band to work.
Old Jan 5, 2009 | 04:01 PM
evo4mad's Avatar
I think serial port code is not working on Vista, I will fix it for the next version of EvoScan.
Old Jan 9, 2009 | 07:27 PM
evo_q8's Avatar
Got everything right and now im into the stangest thing ever. I do my logs and then i go to the Saved Logs folder and i dont see anything! I can only see two sample logs which are there by default. So then i go back to evoscan and try to see the log on the graph to which it opens the SAVED LOGS folder and there it is. I see the log that I did. But when i go back directly to the folder, i only can see the two sample logs.
Searched on the other forums, found out it was something do with Vista Service Pack. The only way to access this file if ya wanna open it in excel is to delete the file and then copy paste it outta the recycle bin.
Old Jan 13, 2009 | 12:29 PM
Oracle1's Avatar
you have permissions not fully functioning.
