evoscan 2.5 w/ vista woes
Old Jan 13, 2009 | 01:49 PM
  #31
nonschlont's Avatar
Originally Posted by evo_q8
Got everything right and now im into the stangest thing ever. I do my logs and then i go to the Saved Logs folder and i dont see anything! I can only see two sample logs which are there by default. So then i go back to evoscan and try to see the log on the graph to which it opens the SAVED LOGS folder and there it is. I see the log that I did. But when i go back directly to the folder, i only can see the two sample logs.
Searched on the other forums, found out it was something do with Vista Service Pack. The only way to access this file if ya wanna open it in excel is to delete the file and then copy paste it outta the recycle bin.
when you open up your saved datalogs folder, and only see the 2 sample logs, you need to hit the compatibility files button and your logs will be in there...
Old Jan 17, 2009 | 09:10 PM
  #32
555R's Avatar
i got it to delete an error code but wont log
i get errors in reference to a driver dpinst something or other
what are the permissions please link it here
its prob something stupid i missed
arrrgghhhh
this is the error
load FTDI Devices: Unable to load DLL 'FTD2XX.dll'; The specified module could not be found. (Exception from HRESULT: 0x8007007E)
and everytime I plug in the openport wire it searches for the openport1.3 universal driver
even after i installed the driver in the USB Driver file
it says i have to run the 64 bit version of the DP Inst.exe on this machine
contact the vendor that provided you with this package
Old Jan 18, 2009 | 11:00 AM
  #33
oldevodude's Avatar
arrrgghhhh
this is the error
If you are using a serial to usb converter for a wideband this would be your problem. You will need to get 64 bit drivers for your usb to serial adapter or the FTDI driver for 64bit didn't upgrade.
Just a theory I'm no pro
Old Jan 18, 2009 | 01:06 PM
  #34
laramie_05MR's Avatar
where would i find something like that? my laptop will not communicate with my wideband
Old Jan 18, 2009 | 08:09 PM
  #35
555R's Avatar
actually i got a pm from hamish and I added ecuflash (the latest version) and it seems to work now
but its snowing out so i cant log anything
i dont want to spend time in a cold car trying to figure it out
i would love to try and tune this on ecuflash but then its my fault if i tune it wrong and destroy my motor
evo7girl
May 30, 2009 07:26 AM
mac214
May 20, 2009 09:25 PM
ant_turbo
Mar 13, 2009 06:48 AM
cky_bam_marg
Feb 3, 2009 01:19 AM
gunhaha
Sep 29, 2008 07:04 PM
