IC settings in Ecuflash??
It would seem after reading through this article http://www.mrtrally.com.au/performan...IX-ICSpray.pdf That the auto mode is basically non functional due to the water temps needed to activate it, Can I simply change my settings through ecuflash to make the ic spray work better? Heres a screenshot of my stock IC settings, im assuming that all the definitions are correct in my rom as they match the stock settings shown in the article.Any suggestions on some decent settings for this or are the ones shown in the article pretty good?
Cheers so really all i need to do is drop the temp down to about 75-70 and it will work in auto mode, I read a lot about this being a bit of a gimmick but figure if its there i might aswell have it working!!
Cheers for the info
On another note I have posted on the tephra thread but you may well know the answer, Will the Tephra patch with spray on knock work in conjunction (spelling
) with these settings or does one eliminate the other if you know what i mean?
plip630
Feb 23, 2009 11:43 PM
