SD - first test success
Old Aug 20, 2009 | 03:37 PM
  #691
l2r99gst's Avatar
No problem, John. I don't expect to you waste anymore time on this with all of the other stuff that I'm sure you are working on. We have others who can continue on. I just appreciate all that you have contributed.
As far as the 3D table and fuel map, yes I agree for open loop tuning, but closed loop tuning, the fuel map isn't going to help. That's where a 3D VE map will help with the granularity.
If I didn't have so much going on, I would teach myself the ROM code...I have the manual. But I think it would take way too long for me to get up to speed to be able to contribute to a project like this. I guess that's what we have tephra and mrfred and the other disassemblers/coders for.
Thanks,
Eric
Old Aug 20, 2009 | 05:26 PM
  #692
EVO8LTW's Avatar
When running SD and the AIT is connected via fuel temp pin (and MAF is removed), what does the ECU use for IAT-related tables? Does it substitute the post-IC IAT? Thx.
Old Aug 20, 2009 | 05:32 PM
  #693
l2r99gst's Avatar
To my understanding, yes. So, it may be wise to adjust certain tables that retard timing due to intake temps, etc.
Old Aug 21, 2009 | 09:50 PM
  #694
evo8dad's Avatar
Quick question - which MAT scaling should we be using? The values stated under the Tephra section or the values stated under JCS SD Programming section? I noticed they are different and wanted to clarify that.
It appears as though the MAT scaling values under Tephra's section should be copied and paste per JCS instructions in parenthesis - just want to confirm this though.
Thanks
Old Aug 22, 2009 | 04:07 AM
  #695
tephra's Avatar
im removing the MAT stuff from my V7 ROM...
less confusing
Old Aug 22, 2009 | 08:03 PM
  #696
evo8dad's Avatar
Ok cool. When is v7 going "public"?
Old Aug 22, 2009 | 08:04 PM
  #697
tephra's Avatar
midweek...
Old Aug 22, 2009 | 08:05 PM
  #698
cossie1's Avatar
are you doing 90550001 too mate ?
Old Aug 22, 2009 | 08:09 PM
  #699
tephra's Avatar
yeah intend too..
96530006 will be first, followed closely by 88590015, then whatever
Old Aug 22, 2009 | 08:10 PM
  #700
cossie1's Avatar
Nice 1 mate.
Mine will be back on the road very soon, with a new spec, so will be nice to have a new rom to play with
Old Aug 27, 2009 | 04:30 PM
  #701
RoadSpike's Avatar
Question for the mod gods.
So lately i've been fine tuning my speed density setup by turning off open loop so i can get a better feel for whats going on during low load where the biggest errors occur. I setup a data item to log the % of deviation between the AFRMap and the logged wideband AFR. But then i came upon this particular oddity.
So I noticed when at idle and low load around 31-33 Load my AFRMap reads 13.8 then jumps to 16.8 alternating every second or so. My fuel map is set to 14.7 so I don't understand why the ECU is spitting out this number.
Help would be appreciated.
Old Aug 27, 2009 | 08:06 PM
  #702
l2r99gst's Avatar
Maybe it's that IPW issue that I have been posting about with SD. Is your IPW jumping/dipping during the AFR spike?
Old Aug 27, 2009 | 08:46 PM
  #703
RoadSpike's Avatar
Yeah i believe it was something like 1.536 to 1.7 something.
Old Aug 28, 2009 | 04:14 AM
  #704
mrfred's Avatar
It would be interesting if this is the issue. There's nothing that I recall in the SD patch that affects the AFRMAP calculation. l2r, if you find that AFRMAP is the issue, I'll take a look at the AFRMAP routines again.
Old Aug 28, 2009 | 05:59 AM
  #705
l2r99gst's Avatar
For me afrmap wasn't the issue. I'm going off of memory, but afrmap was flat in all of my logs during the issue.
