EcuFlash Rainbow Color MAP
Old Feb 17, 2009 | 10:11 PM
Appauldd's Avatar
My color map for v2.41 no longer has the 14.7 as yellow. It is now a shade of red. This is using the same color map as previous versions. I am using the Rainbow default color map just as i did with previous versions of EvoScan.
Does anyone else have this issue?
Old Feb 18, 2009 | 08:38 AM
lemmonhead's Avatar
dont be discrimatory, all colors are equal
Old Feb 18, 2009 | 09:06 AM
Appauldd's Avatar
HA HA.....Seroiusly though....I liked how the color map worked on the Rainbow. It makes for easy veiwing on my laptop in my garage where lighting isn't so ideal.
If someone could send me a copy of the rainbow.MAP file from the EvoScan Color Map Directory, I can fix mine to how it used to be prior to v2.41.
Old Feb 18, 2009 | 02:04 PM
03whitegsr's Avatar
Doesn't the max/min values in the scaling control the colors?
Old Feb 18, 2009 | 02:36 PM
Appauldd's Avatar
You are the MAN ! !
I edited the Max and Min for the AFR scaling from 5 min and 30 max to 7 min and 25 max....voila...back to normal.
Old Feb 18, 2009 | 04:05 PM
C6C6CH3vo's Avatar
You can edit the color map schemes in notepad. It is a tedius process but you basically make your own color map. The numbers are for blue, yellow, and red resp.
Old Feb 18, 2009 | 04:22 PM
Appauldd's Avatar
I saw that I can do that, but the thousands of color combinations was a little daunting for me. Just changing the min and max values that EcuFlash uses for AFR worked perfectly.
Old Sep 19, 2009 | 08:10 PM
Evo_Jay's Avatar
Originally Posted by Appauldd
You are the MAN ! !
I had the problem too. This fix worked.
thx man
Old Oct 5, 2013 | 08:58 AM
TurboTylerIX's Avatar
You are the MAN ! !
Thanks guys!
I should have searched on this sooner, it has been annoying me for a while.
I changed it to 5 min, 20 max which worked best for me.
Old Oct 5, 2013 | 07:41 PM
merlin.oz's Avatar
I also use a variation of rainbow, but set the range to 10 and 15, which also gives nice graduation.
Burnstormer
Mar 3, 2016 03:07 PM
Inzanesrt4
Northwest Region
22
Feb 19, 2010 11:05 PM
Inzanesrt4
Northwest Region
Feb 8, 2009 05:04 PM
TheTumblerIX
12
Nov 26, 2007 07:57 PM
JeffWels
Jan 7, 2004 06:17 AM
