Front speaker mounting depth? Models?
Old Jan 5, 2007 | 11:16 PM
TheTumblerIX's Avatar
Hey guys. Anybody know how deep of a speaker will fit into the stock location without spacers? Or, what speakers have you used without much modification? I've got a set of Rainbow comps on the way, they're not too deep but I just wanted to know if I should anticipate making spacers.
Old Nov 24, 2007 | 06:29 PM
Buschur_TSI's Avatar
I was wondering the same thing I have not had a chance to tear the door apart and I want ot know if my seas lotus ref will fit
Old Nov 24, 2007 | 06:43 PM
atombomb33's Avatar
EvoM Community Team
For speakers as nice as Rainbow or SEAS, you guys might want to consider making MDF mounting brackets. You'll need mounting brackets regardless of which speaker you put in the front or rear...and ABS plastic brackets won't do your speakers justice. If you make your MDF brackets 1/2" thick, you won't have any issues with mounting depth.
Old Nov 24, 2007 | 06:46 PM
yes but I want to retain the stock look of the door panelfrom the outside
Old Nov 24, 2007 | 06:54 PM
atombomb33's Avatar
EvoM Community Team
You won't have to change the door panel at all. I mounted my JL Audio components on 1/2" MDF bracket in the front doors. Stock door panel snaps right back into place. Nothing to worry about there.
Check out my install thread...first 10 pics on the first page...
https://www.evolutionm.net/forums/sh...d.php?t=286896
Old Nov 24, 2007 | 07:28 PM
what worries me is that the mounting depth of the seas is really deep, it's not the fact that opening on the evo is large but I don't know if there is room beacuse of the mounting depth
Old Nov 25, 2007 | 04:21 AM
LayinLo's Avatar
The opening is 6.75" and that is why you will need a mounting bracket.
Old Nov 25, 2007 | 06:07 AM
I understand that what I am worried about is the depth not the diamater of the opening. If the depth in the door is only say 2.5" and my speakers need 3.5" then I will mosty likely not be able to get them in there with out cutting the door panel.
Old Nov 25, 2007 | 03:18 PM
atombomb33's Avatar
EvoM Community Team
Holy Jesus! 3.5" depth! Well, they definitely won't fit without a spacer/bracket. You'll need at least .75" thick...maybe even 1" thick.
I still think they'll fit. On the inside of the plastic door panel, there is plenty of room for a thick bracket. You may need to do a little trimming, but overall, I don't think you'll need to modify the part of the door panel that faces the inside of the car.
Old Nov 26, 2007 | 01:19 PM
well that was just an example. The actual mounting depth is aroun 2.25 inches or so.
Old Nov 26, 2007 | 02:03 PM
atombomb33's Avatar
EvoM Community Team
At 2.25" you're fine. My speakers are 2.65" deep. My MDF brackets are 1/2" thick and the stock door panels easily fit over them. You're fine
Old Nov 26, 2007 | 03:14 PM
LayinLo's Avatar
Thats cool.
2.25" is fine.
I recommended the spacer because then you will definitely have enough room and will have soom space for dynamat behind the speaker.
Old Nov 26, 2007 | 07:57 PM
WhiteEvo05's Avatar
You have nothing to worry about... https://www.evolutionm.net/forums/sh...d.php?t=268295
PriusRepellent
Feb 7, 2016 06:54 PM
OZKID
Apr 2, 2013 06:46 PM
MidMex
Feb 24, 2010 04:15 PM
lhomme
Nov 13, 2008 11:17 AM
TearItUpSports
Mar 7, 2003 11:12 AM
