Is the jdm map sensor required ?
Old Feb 20, 2009 | 05:23 AM
antilag_200's Avatar
Hello folks,
Is the JDM map sensor required, to disable the egr functions in ecuflash ?
I am speaking of the changes that need to be done in the .xml FILE
thank you for your time
warren
Old Feb 20, 2009 | 05:36 AM
Appauldd's Avatar
Disabling the EGR functions is done with the Periphery bits. No the JDM MAP isn't required.
To do it.....
Change FCA bit 9 to 0 (EGR test function)
Change FAA bit 11 to 1 (EGR disable)
Old Feb 20, 2009 | 05:40 AM
SkyNight's Avatar
FAA bit 11 to 1
FCA bit 9 to 0
PS: In 88580014 but I think also in 88590015
Old Feb 20, 2009 | 06:40 AM
my internal id is 94170015
I modified my ROM with these instructions
https://www.evolutionm.net/forums/ec...tructions.html
where is the FAA AND FCA in ECUFLASH, sorry for the Noob questions
Old Feb 20, 2009 | 06:55 AM
Appauldd's Avatar
You have to add the "Periphery Bits" to the XML in order to have them. I pasted it all in the Evo7Base so that any car I tun will have them.
Past the code below into your XML at the bottom before the </rom>
<table name="ECU Periphery00 Hex" category="Periphery" address="f9a" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Periphery0 Hex" category="Periphery" address="faa" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Periphery1 Hex" category="Periphery" address="fba" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Periphery2 Hex" category="Periphery" address="fca" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Periphery3 Hex" category="Periphery" address="fda" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Periphery4 Hex" category="Periphery" address="fea" type="1D" level="2" scaling="Hex16"/>
<table name="ECU Periphery00 (F9A) Bits" category="Periphery" address="f9a" type="2D" level="2" scaling="blobbits">
<table name="Periphery Bit Number" type="Static Y Axis" flipy="true" elements="16">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery0 (FAA) Bits" category="Periphery" address="faa" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery1 (FBA) Bits" category="Periphery" address="fba" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery2 (FCA) Bits" category="Periphery" address="fca" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery3 (FDA) Bits" category="Periphery" address="fda" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="ECU Periphery4 (FEA) Bits" category="Periphery" address="fea" type="2D" level="2" scaling="blobbits">
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<table name="OBD-II Codes" category="OBD-II" type="3D" level="2" scaling="Hex16">
<table name="r4 (hex)" type="Static X Axis" elements="16" scaling="Hex16">
<data>8000</data>
<data>4000</data>
<data>2000</data>
<data>1000</data>
<data>800</data>
<data>400</data>
<data>200</data>
<data>100</data>
<data>80</data>
<data>40</data>
<data>20</data>
<data>10</data>
<data>8</data>
<data>4</data>
<data>2</data>
<data>1</data>
</table>
<table name="r5 (hex)" type="Static Y Axis" elements="13">
<data>00</data>
<data>01</data>
<data>02</data>
<data>03</data>
<data>04</data>
<data>05</data>
<data>06</data>
<data>07</data>
<data>08</data>
<data>09</data>
<data>0A</data>
<data>0B</data>
<data>0C</data>
<data>0D</data>
<data>0E</data>
<data>0F</data>
</table>
</table>
Old Feb 20, 2009 | 07:24 AM
Thank you very much for the help
I did what you said and copied everything to the 94170015 xml file
this is what that screen looks like
Now I typed in the values that you told me in the right hand column, but nothing changed( visually) is that correct ?
Old Feb 20, 2009 | 07:56 AM
Appauldd's Avatar
Sorry.....forgot this part...
<scaling name="blobbits" storagetype="bloblist" storagebits="1">
<data name="0" value="00"/>
<data name="1" value="01"/>
Add it to the bottom of the scalings, which are at the top of the XML
Old Feb 20, 2009 | 08:03 AM
I not sure what you mean and where to place the scaling part... I am sorry about not being so computer savey
Old Feb 20, 2009 | 08:06 AM
Appauldd's Avatar
At the top of the XML there will be a listing of "scalings".....it should look like this.....
</romid>
<include>evo7base</include>
<scaling name="AirFlowHZ" units="units" toexpr="x/10.24" frexpr="x*10.24" format="%.0f" min="0" max="6400" inc="1" storagetype="uint16" endian="big"/>
<scaling name="int16" units="units" toexpr="x" frexpr="x" format="%.3f" min="-32767" max="32767" inc="1" storagetype="int16" endian="big"/>
<scaling name="ThrottlePercentage" units="%" toexpr="x/255*100" frexpr="x*255/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint16"/>
<scaling name="1bytefactor" units="units" toexpr="x/((32/10)*100)" frexpr="x*((32/10)*100)" format="%.1f" min="1" max="2" inc="0.1" storagetype="uint16" endian="big"/>
<scaling name="ECUTime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="1" storagetype="uint16" endian="big"/>
</scaling>
Old Feb 20, 2009 | 08:11 AM
hmm I don't have anything like that in mine,
here is what mine looks like
<rom>
<romid>
<xmlid>94170015</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>94170015</internalidhex>
<caseid>MN132874</caseid>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO8</submodel>
<transmission>Manual</transmission>
<year>2004</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<table name="High Octane Fuel Map" address="33bd">
<table name="Load" address="6694" elements="18"/>
<table name="RPM" address="666c" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="34d7">
</table>
<table name="High Octane Ignition Map 1" address="39d5">
<table name="Load" address="66f4" elements="19"/>
<table name="RPM" address="66c2" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3b5d">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="37c0">
<table name="Battery Voltage" address="65d4" elements="7"/>
</table>
<table name="Rev Limit" address="158c"/>
<table name="Stationary Rev Limit" address="2b4a"/>
<table name="Accel Enrichment" address="3864">
<table name="RPM" address="6406" elements="15"/>
</table>
<table name="Boost Control Load Offset" address="1a70"/>
<table name="Turbo Boost Error Correction" address="4488">
<table name="Boost Error" address="69ac" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="44f8">
<table name="RPM" address="6982" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="450e">
</table>
<table name="Boost Desired Engine Load # 3" address="4524">
</table>
<table name="Boost Desired Engine Load # 4" address="453a">
</table>
<table name="Max Wastegate Duty # 1" address="44a0">
</table>
<table name="Max Wastegate Duty # 2" address="44b6">
</table>
<table name="Max Wastegate Duty # 3" address="44cc">
</table>
<table name="Max Wastegate Duty # 4" address="44e2">
<table name="RPM" address="6982"/>
</table>
<table name="Open Loop Load # 1" address="3624" scaling="ThrottleVoltage">
<table name="RPM" address="6378" elements="15"/>
</table>
<table name="Open Loop Load # 2" address="363a" scaling="ThrottleVoltage">
</table>
<table name="Open Loop Throttle Low Load" address="3656">
</table>
<table name="Open Loop Throttle High Load" address="366c">
</table>
<table name="IC Relay Timer Time" address="2498">
<table name="Condition"/>
</table>
<table name="IC Relay Timer Control Judgement" address="209e">
</table>
<table name="IC Relay Timer Air Temp" address="20a2"/>
<table name="IC Relay Timer ON Mode Switch Time" address="247e"/>
<table name="IC Relay Timer Control RPM" address="2480"/>
<table name="IC Relay Timer Control Water Temp" address="2482">
</table>
<table name="IC Relay Control Vehicle Speed" address="2486"/>
<table name="IC Relay Control EV" address="2488"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="4276">
<table name="Engine Temp" address="68b8" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="4284">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="4292">
</table>
<table name="Desired Idle RPM-Neutral" address="425a">
</table>
<table name="Desired Idle RPM-Drive" address="4268">
</table>
<table name="High Intake Air Temp ISCV Increase" address="220e">
<table name="Condition" elements="2"/>
</table>
<table name="Boost Limit" address="3614">
<table name="RPM" address="6b7e" elements="9"/>
</table>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1680"/>
<table name="Desired Idle RPM with AC on" address="186c">
</table>
<table name="High Intake Air Temp Idle Speed Target" address="220a">
</table>
<table name="Wastgate Solenoid Activation RPM" address="1668">
</table>
<table name="Speed Limit" address="158e">
</table>
<table name="Injector Scaling" address="1506"/>
<table name="Min Coolant Temp for Closed Loop" address="15aa"/>
<table name="Boost Cut Delay Timer" address="159a"/>
<table name="MAF Scaling" address="3306" scaling="AirFlow8">
<table name="Load" address="6584" elements="21"/>
</table>
<table name="MAF Smoothing Table" address="3322">
</table>
<table name="Air Temperature Compensation" address="333e" scaling="uint8">
<table name="Degrees" address="68b8" elements="8"/>
</table>
<table name="Barometric Pressure Compensation" address="3351">
<table name="Atmosphere Pressure" address="6572" elements="4"/>
<table name="RPM" address="65b8" elements="9"/>
</table>
<table name="Idle Stepper Look-up Table" address="4399">
<table name="Throttle Position" address="68b8" elements="8"/>
<table name="RPM" address="68d2" elements="27"/>
</table>
<table name="Knock Sensor Filter Map 1" address="485b" level="4">
<table name="TAR" address="6a8a" elements="12"/>
<table name="RPM" address="6a6a" elements="11"/>
</table>
<table name="Knock Sensor Filter Map 2" address="48eb">
</table>
<table name="Knock Sensor Filter Map 3" address="497b">
</table>
<table name="Knock Sensor Filter Map 4" address="4a0b">
</table>
<table name="Knock Sensor Filter Map 5" address="4a9b">
</table>
<table name="Knock Sensor Filter Map 6" address="4b2b">
</table>
<table name="Knock Sensor Filter Map 7" address="4e09">
</table>
<table name="Knock Sensor Filter Map 8" address="4e99">
</table>
<table name="Knock Sensor Filter Map 9" address="4f29">
</table>
<table name="Knock Sensor Filter Map 10" address="4fb9">
</table>
<table name="Knock Sensor Filter Map 11" address="5049">
</table>
<table name="Knock Sensor Filter Map 12" address="50d9">
</table>
<table name="MAF Sensor Filtering" address="1508">
<table name="Load"/>
</table>
<table name="MAF Size" address="150c"/>
<table name="Min Temp for Full Boost Control" address="2200"/>
<table name="Boost Control Limiting Vehicle Speed" address="2204">
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1682" level="3"/>
<table name="Boost Enhancement (Anti-lag) Table" address="39b6">
<table name="RPM" address="6654"/>
</table>
<table name="Wastegate Compensation" address="4478"/>
<table name="Boost Enhancement Adv/Ret Map 1 (Anti-lag)" address="3ce5">
<table name="Load" address="66f4"/>
<table name="RPM" address="66c2"/>
</table>
<table name="Boost Enhancement Adv/Ret Map 2 (Anti-lag)" address="3e6d">
<table name="Load" address="66f4" scaling="Load"/>
<table name="RPM" address="66c2" scaling="RPM"/>
</table>
<table name="Boost Enhancement Enrich/Enlean (Anti-lag) Map" address="3ff5">
</table>
<table name="MAP Test 1: Mid VE Max Voltage" category="MAPSensor" address="2048" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 1: Mid VE Min Voltage" category="MAPSensor" address="2046" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 2: Low VE Max Voltage" category="MAPSensor" address="204C" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 3: High VE Min Voltage" category="MAPSensor" address="2050" type="1D" level="1" scaling="Volts16"/>
<table name="EGR MAP Check 1" category="MAPSensor" address="4DE4" type="2D" level="1" scaling="uint8">
<table name="RPM" address="6C0A" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="EGR MAP Check 2" category="MAPSensor" address="4DF4" type="2D" level="1" scaling="uint8">
</table>
<table name="EGR Pressure Diff" category="MAPSensor" address="1F62" type="1D" level="1" scaling="Volts16"/>
<table name="ECU Periphery2" category="ECUPeriphery" address="fca" type="1D" level="1" scaling="Hex16"/>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>8000</data>
<data>4000</data>
<data>2000</data>
<data>1000</data>
<data>800</data>
<data>400</data>
<data>200</data>
<data>100</data>
<data>80</data>
<data>40</data>
<data>20</data>
<data>10</data>
<data>8</data>
<data>4</data>
<data>2</data>
<data>1</data>
</table>
<data>00</data>
<data>01</data>
<data>02</data>
<data>03</data>
<data>04</data>
<data>05</data>
<data>06</data>
<data>07</data>
<data>08</data>
<data>09</data>
<data>0A</data>
<data>0B</data>
<data>0C</data>
<data>0D</data>
<data>0E</data>
<data>0F</data>
</table>
</table>
</rom>
Old Feb 20, 2009 | 08:14 AM
Appauldd's Avatar
I added it for you. Just copy and past the whole thing back into your XML and all should be good.
<rom>
<romid>
<year>2004</year>
</romid>
</scaling>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>bit.15</data>
<data>bit.14</data>
<data>bit.13</data>
<data>bit.12</data>
<data>bit.11</data>
<data>bit.10</data>
<data>bit.9</data>
<data>bit.8</data>
<data>bit.7</data>
<data>bit.6</data>
<data>bit.5</data>
<data>bit.4</data>
<data>bit.3</data>
<data>bit.2</data>
<data>bit.1</data>
<data>bit.0</data>
</table>
</table>
<data>8000</data>
<data>4000</data>
<data>2000</data>
<data>1000</data>
<data>800</data>
<data>400</data>
<data>200</data>
<data>100</data>
<data>80</data>
<data>40</data>
<data>20</data>
<data>10</data>
<data>8</data>
<data>4</data>
<data>2</data>
<data>1</data>
</table>
<data>00</data>
<data>01</data>
<data>02</data>
<data>03</data>
<data>04</data>
<data>05</data>
<data>06</data>
<data>07</data>
<data>08</data>
<data>09</data>
<data>0A</data>
<data>0B</data>
<data>0C</data>
<data>0D</data>
<data>0E</data>
<data>0F</data>
</table>
</table>
</rom>
Old Feb 20, 2009 | 08:28 AM
thank you very much for your help, I did what you said
and this is what the picture says "no match" so when I try to enter values, it does not change anything in the right hand column
sorry for being a pain in your ***
Old Feb 20, 2009 | 08:49 AM
Appauldd's Avatar
What version of EcuFlash are you using?
Periphery bits only work on v1.35 and higher.
Old Feb 20, 2009 | 09:14 AM
AHHH there is the problem, I am using 1.30 . I will download the new ecuflash and go from there, thank you ever so much for all your help
Old Feb 20, 2009 | 09:28 AM
Appauldd's Avatar
No Prob....glad i could help out.
