TPS 13.3% minimum wtf
Old Feb 26, 2009 | 09:40 AM
leecavturbo's Avatar
TPS showing/logging 13.3% minimum wtf
is this just how it is?
Old Feb 26, 2009 | 09:43 AM
Cyloc's Avatar
mine usually sits around 14.0 to 14.5
Old Feb 26, 2009 | 09:46 AM
recompile's Avatar
This is normal for a mitsubishi. It's also normal if it only reads 98-99% when WOT.
Old Feb 26, 2009 | 09:47 AM
lilnaz's Avatar
Mine is exaclty 13.3 also, normal.
Old Feb 26, 2009 | 10:24 AM
GST Motorsports's Avatar
I imagine that is a OBD2 thing as raw TPS signals show 0% and 100%
Old Feb 26, 2009 | 10:27 AM
MR Turco's Avatar
I have never seen this on any evo i have tuned. I think your tps might not be set correctly.
Old Feb 26, 2009 | 10:29 AM
I've seen more 99 and 99.5 than 100. Even on 100% bone stock evos.
Old Feb 26, 2009 | 10:42 AM
laramie_05MR's Avatar
mines reads 13.3@ idle and 99@ wot
Old Feb 26, 2009 | 10:56 AM
MR Turco's Avatar
wow i mean given i have only tested 10 or so cars but yeah i have never seen it.
Old Feb 26, 2009 | 11:16 AM
Kickn' it old school with PocketLogger showing 99.41:
Evoscan 99.6:
Old Feb 26, 2009 | 11:18 AM
MR Turco's Avatar
I wonder for those what the TPS reads at idle.
Old Feb 26, 2009 | 12:57 PM
nonschlont's Avatar
mine reads 14% tps (min.) @ idle and I actually get 100% @ wot.
Old Feb 26, 2009 | 01:02 PM
C6C6CH3vo's Avatar
0.41 volts to 5.00 volts for closed to wide open.
Old Feb 26, 2009 | 08:10 PM
Appauldd's Avatar
Using EvoScan with the ignition key on and the engine not running you can test your TPS. I noticed with mine that with the throttle fully closed it would read about to 14%. Then at full throttle I was only hitting 97%. There are 2 screws that hold the TPS in place. Loosen them a little and turn the TPS so that you get 100% at full throttle. Once this is done your closed throttle should read between 7% and 9% depending on your TPS. Be sure to disconnect your battery to reset the ECU. Once you start it up the ECU will learn the new TPS position.
You will notice a tad better throttle response too.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
