Links to jcsbanks' Speed Density patches
Old Sep 14, 2009 | 08:22 AM
  #241
lan_evo_mr9's Avatar
Ok, so it's actual load that goes in the right column, not a percentage. How do you know what % of VE you are at at that point?
Old Sep 14, 2009 | 08:38 AM
  #242
evo8dad's Avatar
VE = Load/MAP (in kPa). You can take the log your are trying to determine VE with and use Excel's features to give you a column of VE based off of the Load column divided by the MAP (in kPa) column.
I've found it easier to just use Excel rather than EvoScan's MAP Tracing but, mostly because I can never get MAP Tracing to work
The VE table that is setup from JCS is pretty damn spot on and really doesn't need to be touched, especially on a stock turbo but, I always confirm the table through logging on the MAF sensor.
  #243
l2r99gst's Avatar
Right column divided by left column.
Your final VE will be that multiplied by the RPM VE.
So, if you have your MAP VE at:
10 7.7
and RPM VE at 1000 RPM at 90%
then final VE is 7.7/10 * .9 = 69% at 1000RPM and 10kpa.
What you are trying to do with the SD tuning is to match your VE from MAF based logs. Before going to SD, ideally you should have made some logs and a 3D chart of your VE (load/map). That is what you use as a starting point to make your initial SD VE tables. Then, switch to SD, and fine tune from there.
It's pretty simple though. Just put what load you see at what map in the map ve table. Then adjust RPM VE at the extremes and readjust the map ve again, if needed, since the final VE is the multiplication of the two.
Eric
Old Sep 14, 2009 | 09:31 AM
  #244
EVO8LTW's Avatar
My loads are generally higher than my MAP in kPa, so does that mean my VE is over 100%? Car is running a Red and makes much more power than a stock turbo at my boost level.
Old Sep 14, 2009 | 09:36 AM
  #245
l2r99gst's Avatar
For tuning the VE tables for this SD patch, yes.
Old Sep 14, 2009 | 10:01 AM
  #246
evo8dad's Avatar
For sure. I've actually seen VEs over 100% on stock turbo'd Evos running high boost.
Old Sep 14, 2009 | 10:39 AM
  #247
the_mork's Avatar
You shouldn't ever have over 100%VE in that table. 100%VE is the maximum VE of your motor regardless of whether load is higher than MAP. Rescale so that you have 100% VE as your maximum setting, or don't since it isn't a huge deal.
What isn't working with evoscan map tracing? A lot of people miss it but you need to load a rom in maptracer to get the scaling for load/rpm. Just right click on the bottom set of cells and you can load a set of definitions and a rom.
Old Sep 14, 2009 | 03:03 PM
  #248
jrohner's Avatar
Then he would just have to retune the map vs load table. What's the difference?
Old Sep 14, 2009 | 03:05 PM
  #249
0xDEAD's Avatar
Actually you are wrong. You can and do go over 100% VE especially on modified cars.
Old Sep 14, 2009 | 03:15 PM
  #250
RoadSpike's Avatar
I think the nomenclature of VE in the speed density table is somewhat misleading. It really in this case is more like a load % gain than a VE.
Its use is more like that of an old audio amp squashing or amplifying dynamics in the load rather than saying that its this efficient. I totally however understand the need to call it VE rather than load gain due to its acceptance in the tuning field.
At this point I've noticed that the dynamics in load at lower rpms are perhaps a bit higher than the table can reasonably accomplish. However a bit of clever map scaling and some added fuel in the fuel table easily remedies this. The fuel table may look slightly off due to this but its a small price to pay for the gains.
Old Sep 14, 2009 | 03:22 PM
  #251
Originally Posted by l2r99gst
Here are the settings that I used for the Omni 4-bar. If you are using the Omni 4-bar, you have to make sure that you map 16bit scaling is ECUFlash is set correctly. It should be:
Code:
<scaling name="MAP 16bit" units="kPa" toexpr="x/2.472" frexpr="x*2.472" format="%.1f" min="0" max="450" inc="0.4" storagetype="uint16" endian="big"/>
That being said, these were my settings when I was running the Omni 4-bar for SD. As others said though, these may end up being a bit different for your car, but it can give you an idea:
Map VE:
Code:
10     7.7
40     32
50     41
60     48
70     60
80     70
120    120
408    408
RPM VE:
90
95
95
97
97
97
100
100
100
96
96
96
96
94
92
88
87
Eric
How is it that definition wasn't included in Mrfred's omni 4bar settings definitions? Or maybe it was and I just missed it. That definition goes into the base file correct?
Edit: the definition is there but some of the toexp are different. Which one is correct?
This is what he has as the omni 4 bar def:
<scaling name="MAP 16bit" units="kPa" toexpr="x*0.4072" frexpr="x/0.4072" format="%.1f" min="0" max="450" inc="0.4072" storagetype="uint16" endian="big"/>
Old Sep 14, 2009 | 03:45 PM
  #252
l2r99gst's Avatar
Those two definitions are the same.
1/2.472 = .4045 (You have .4072, which is just about the same...not sure which was the 'final' value settled on). I could have pulled my scaling from old notes, as this isn't my tuning computer. So, you can use the one that you have listed.
But the point is that you need that scaling for the Omni 4-bar.
Old Sep 14, 2009 | 03:49 PM
  #253
Gotcha- I already had it in there, was just confused on the values.
Old Sep 14, 2009 | 04:22 PM
  #254
One thing I don't understand (shocked), is why there is such a jump in the MAP VE table between 120 and 408 in l2r99gst's table and not in Mork's table. Anyone care to explain?
Old Sep 14, 2009 | 04:28 PM
  #255
RoadSpike's Avatar
One thing I don't understand (shocked), is why there is such a jump in the MAP VE table between 120 and 408. Anyone care to explain?
its not really a jump the x value moves too it just interupts the values in between as a linear function of X.
