Links to jcsbanks' Speed Density patches
cossie1 found that the MAP just plugs into the correct pin (no ECU changes, just appears on the usual MAP sensor logging channel) and you can mount a GM temp sensor in the inlet manifold or wherever you wish.
John, I can't see MAT calibration xml elsewhere for 90550001. Do you have it?
I've never written anything on setting up MAP or MAT for that ROM. cossie1 might be the person to ask about that ROM.
i dont have IAT yet, i have been looking to see if i can log it first. didnt see a need to set up a bunch of accesories if there wasent a big need for it. i still need to get my hands on a JDM MAP... or a GM MAPiy that works also..
Have you guys decided where its best to mount the iat sensor yet ? Whether its on the manifold for MAT or on the UICP for IAT ?
Just curious because I ordered a new uicp from TTR and may have them just weld the bung on while its there.
Thanks
Edited:: Wanted to add whether or not if I need to change the xml files back over from the SD patched rom to a non SD rom ? Just wondering because I made a back up either way and wanted to know if it was needed.
Thanks
Not using baro for now. The arguments either way vary, some (including AEM) think that you don't need it on a speed density system. Others think you do because the VE changes due to exhaust pressure. We are waiting for variable altitude drivers to test it. A baro sensor could be mounted in the engine bay and new compensation tables written if required. A more accurate load measurement may well be MAP/baro. OEM system is volume airflow*baro. It is quite complex, and it seems that many aftermarket ECUs and some OEM ECUs don't do baro comp well.
I think the best place for the temp sensor is the inlet manifold, followed by the UICP, followed by the air intake, followed by none at all which does work in some climates!
now back to my original questions
:-when wll this be released for other roms (88840017 for example)
-if my car didn't have a map sensor originally, is it enough to just wire one in to the correct ecu pin, or are other ecu modifications required?
Should be enough just to wire it in.
Release for others, not sure yet, and who is doing it. Tephra did Aus 9, mrfred did US 8 and 9, I did JDM 7 and 9. I have been intending to do JDM 8 next, but presently I'm working on some stuff for essevo and others so they don't emulate a MAF on their strokers and big turbos, but rescale it more sensibly, and also thinking about baro corrections for altitude.
Just making sure before i start screwing with my car..... again. I should be able to install an IAT sensor in the manifold and wire it to pin pin 6 on the MAF plug and be GTG? That should be fun... at the moment i have a MAFT gen2 installed. decisions, decisions.
My problem is this: I want to use an AEM 3.5bar MAP sensor for my SD setup using 90550001. I was searching through the ROM code trying to find the voltage scaling for the oem 3.5bar as Mrfred describes in his patch thread and don't see it anywhere. I thought this scaling was necessary for the ECU to interpret the voltage signal and convert it to a correct pressure reading but maybe I am not understanding something. So how is it working with the 90550001 and what do I need to do to get it to work with the AEM sensor?.
