Links to jcsbanks' Speed Density patches
Reasons:
1) Better overall power for larger turbo setups
2) Cam lope is easier to control
3) Of course crazy BOV's can now be used like Tial
4) You no longer have to adapt the maf for large turbos like 35r or bigger turbos
I've search a lot, and read a lot of threads, but I m disapointed, I didn't find the way to use SD with tephra V7 rom 88580014, original rom EDM 88840016.. Can someone help me please.
I have all the hardware, AEM 3.5 bar MAP sensor and GM MAT sensor,...just need to remove intake manifold to install...
Thanks in advance...
Question ...
I don't have an entry labeled "SD Option." Has this been relabeled "SD Convert IAT to MAT?" That's the only table I see that uses the format mentioned. Original value is 0x03.
I'm using the XML provided in the download.
3) OPTIONAL SD PATCH SETTING: The SD patch can read MAT from either the fuel tank temperature ADC or the IAT ADC. The patched ROM is set to use the fuel tank temperature ADC. If you want to use the IAT ADC, find the "SD Option" entry, and change it to "0x03".
Yep, that's the table covered in the instructions.
Since the links to: 90550001 ROM: http://banks.myzen.co.uk/90550001-v5.10fix-mods-SD.zip are broken ( server no longer available ) Does anyone has an backup of that ROM with xml? What i need is to rescale the Map sensor from JDM/EVO x 3 bar to an Omni 4 Bar Many thanks in advance Steffen
