Map Switching Help
Old Mar 2, 2009 | 06:20 PM
rolly1818's Avatar
Registered User
Map Switching Help
i have a JDM 2006 Evo IX.
i recently started tuning and now i cannot get the map switch to work with the I/C switch for some reason. every time i switch i see it light up but nothing happens i get basically the same response as on the normal map.
i changed from my JDM ROM to ROM id - 88580014.
not sure why this happens but my stationary rev limit does not work either.
i am hoping its not a problem presented by JDM IXs, my friend has a JDM VIII MR and it works fine through the I/C spray though.
any ideas?
Thanks in advance
Old Mar 2, 2009 | 06:35 PM
tephra's Avatar
does the ics spray lamp flash?
what is your activation time for autoics?
Old Mar 2, 2009 | 06:49 PM
rolly1818's Avatar
Registered User
lamp does not flash just comes on and stays on.
time for alt map switch is set to 1500ms.
BTW sorry to hear about your car, at least your in one piece!
Old Mar 2, 2009 | 06:59 PM
tephra's Avatar
ok.
what have you got as your "altmap master enable" in the tephramod options?
edit - thanks still dunno whats happening, but its looking more and more like a writeoff
Old Mar 3, 2009 | 05:48 AM
rolly1818's Avatar
Registered User
ok.
bro, i have no clue what that is. all i am seeing are the following -
alt map time to activate
alt map load threshold
alternate map ADC0F threshold
and the other normal stuff like igition, octane, WGDC and BDEL.
dont worry when you get back YOUR evo or A evo you will be happier.
just dont buy an STI
Old Mar 3, 2009 | 03:05 PM
tephra's Avatar
in the main tephramod options box (the one with all the 1's and 0's)
Old Mar 4, 2009 | 05:41 AM
rolly1818's Avatar
Registered User
on the main tephramod options it has the following:
Enable Alternate Map Masters? ADC0F=1? AutoICS=2 i have it set at 2.
i tried 1 and nothing happened.
would you like a picture of my rom showing the Alt Map settings?
Old Mar 4, 2009 | 05:58 AM
Evoryder's Avatar
shouldn't it be ADC0F=0? AutoICS=1
What version do you have? V5?
Old Mar 4, 2009 | 05:59 AM
rolly1818's Avatar
Registered User
yup V5, rom id = 88580014!
thats y i am asking for help
Old Mar 4, 2009 | 06:28 AM
Evo8Emperor's Avatar
Mines the same as his and I run 5.10.
Old Mar 4, 2009 | 06:41 AM
rolly1818's Avatar
Registered User
^^ does yours work.
i hope its not the whole JDM thingy!
Old Mar 4, 2009 | 10:32 AM
leecavturbo's Avatar
no 1 and 2 respectively
Old Mar 4, 2009 | 10:34 AM
Wicked E's Avatar
0 = disable for either mode
1 = Enable for ADCOF
2 = Enable for AutoICS
Old Mar 4, 2009 | 10:36 AM
rolly1818's Avatar
Registered User
i gathered as much, but still now working lol.
Wicked E's Avatar
I was clearing that up for others...
-E
