Possible to log MAT and ambient?
Old Mar 3, 2009 | 07:01 PM
Kracka's Avatar
I'd really like to also be able to log ambient temp too. Is there any way to wire in another GM AIT sensor to the ECU that could be used for measuring ambient temps?
Here is a graph showing air temps at the MAF (blue) vs. air temps inside the intake manifold (purple). This was a 3rd gear pull on DB's dyno.
Old Mar 3, 2009 | 07:07 PM
scheides's Avatar
EvoM Moderator
mrfred, weren't you going to try and do this somehow?
Old Mar 3, 2009 | 07:18 PM
tephra's Avatar
MAFIAT is the same as ambient (once it bottoms out)
so in your above graph, the blue line bottoms out at 75 degF. so your ambient would be 75. does that sound right?
Personally I think your MAT (unless u got WorM/I) is reading low...
Old Mar 3, 2009 | 08:44 PM
Kracka's Avatar
I'm on straight pump gas, nothing injected. The GM AIT sensor in the intake manifold (MAT) reads the same as the MAF when the car is cold which leads me to believe it is fairly accurate.
Old Mar 3, 2009 | 08:51 PM
tephra's Avatar
ok... maybe its ok then...
haxr303
Jul 3, 2016 07:50 PM
Boostedx11
Sep 15, 2012 09:42 AM
crcain
46
Mar 8, 2010 07:35 PM
razorlab
Jul 4, 2008 10:46 AM
EvO6-RS2
17
Jul 12, 2006 07:08 PM
