evoscan logging incorrect innovate afr
Old Mar 11, 2009 | 11:06 AM
nitz's Avatar
well i don't have much faith in the evoscan trouble ticket system, since i've had one open since jan 1st with no reply so i thought i'd try my luck here. my lc1 reads perfectly via gauge and serial logworks 3 software. however, evoscan logs values like 3.xxx, 4.xxx and 5.xxx for some odd reason. i tried an lm1 which had better results but every 5 entries or so would read 14.583 no matter what the actual afr was. i've tried numerous versions of evoscan. any ideas?
Old Mar 12, 2009 | 08:23 AM
nitz's Avatar
anyone?
Old Mar 12, 2009 | 08:38 AM
Fast_Freddie's Avatar
Veteran: Navy
Which com port do you have selected... make sure that the serial to usb for the LC1 is set up on com ports 1-3 or this will happen...
Old Mar 12, 2009 | 09:24 AM
rolly1818's Avatar
Registered User
there was a similar problem with a guy on here. search and you should find it, i think they found the solution.
Old Mar 12, 2009 | 09:55 AM
nitz's Avatar
thanks, but i don't use a serial to usb adapter, my notebook has a serial port. it is set to use com port 1 always.
Old Mar 12, 2009 | 09:56 AM
nitz's Avatar
i've tried searching many times and read many threads without luck. i'll give it another shot. thanks.
Old Mar 12, 2009 | 03:38 PM
nothere's Avatar
are you seeing this on the chart or the csv file?
Old Mar 13, 2009 | 12:39 PM
Veteran: Navy
Make sure you plug the serial connector into the LC-1 and your computer before you power up the LC-1 also...
Old Mar 13, 2009 | 04:47 PM
chrisw's Avatar
check the programming on the LC-1. Make sure that the serial output is properly programmed. If this is incorrect than you can get weird results logging with Evoscan.
Old Mar 13, 2009 | 05:11 PM
leecavturbo's Avatar
^ likewise power down completely before unplugging the serial port.
all you need do is open lmprogrammer and reset calibration to gas. works everytime
Old Mar 14, 2009 | 09:59 AM
nitz's Avatar
thanks guys. i found another thread with someone that had the same problem, and it was indeed the output programming on the lc1. it got reset to custom instead of gasoline. this apparently happens sometimes after a free air calibration. what was throwing me off was that logworks was showing correct afr's. you would think this would be off as well, but i guess it's not a true output??. the db guage was reading right as well because it's just a 0-5v analog guage which uses separate analog output programming. now if i can only figure out why i get repeated 14.2737 entries in evoscan 2.6 and empty cells in 2.5.
Old Nov 10, 2010 | 07:45 AM
Kakihara's Avatar
I just installed an LC-1 on my evo but couldn't log it in evoscan
I only had 6.3-6.5 reading in evoscan
Then I saw leecav post and when I opened lmprogrammer it was set for : (6.3) custom fuel.
I selected (14.7) gasoline and that was it.
No problem logging afr in evoscan now.
Thanks man.
Old Nov 13, 2010 | 06:04 PM
joshesh's Avatar
bump for a similar issue
I can get logworks to log my LC-1 but for some reason Evoscan 2.6 won't read it at all. I tried different com ports and still no worky.
Old Nov 13, 2010 | 06:06 PM
but did you actually find which com port your lc1 is on from control panel/system/device manager etc?
Old Nov 13, 2010 | 09:35 PM
joshesh's Avatar
yes, com port 5
