evoscan logging incorrect innovate afr
Old Nov 14, 2010 | 03:59 AM
leecavturbo's Avatar
When programming the lc1 for gasoline etc you must ensure your car battery voltage is high 12.7v+ just because your battery may start your car that's not a indication of good voltage
While the car is running will give good voltage and usually works but I prefer a ripple free voltage for programming its so much more reliable. You can do that by running the car for ten minutes then as soon as you switch off engine then do the programming. Alternatively connect a charger
Old Nov 8, 2011 | 11:15 PM
10isace's Avatar
Bumping an old thread Sorry.
I did the re-calibrate in LM Programmer and it was set to custom, fixed it for gasoline. Evoscan then logged perfectly. That was 2 days ago. Fast forward to today and now evoscan reads 0 for AFR's
So I did the LM Programmer deal, but it was already set to gasoline. WTF? Has anybody experienced this? Help, I need to log, I'm having withdrawals.
Old Feb 19, 2013 | 03:34 PM
kaj's Avatar
kaj
nm
D1andonlyantman
13
Apr 19, 2017 06:39 AM
evo jason
Jan 7, 2012 04:25 AM
evo9_jdm
May 7, 2010 09:04 AM
evo8dad
Jan 31, 2009 03:48 PM
boldtx
Mar 24, 2008 04:22 PM
