Write new code?
Old May 19, 2009 | 11:32 PM
  #46
tephra's Avatar
obviously choose an address that isn't DIRECTLY referenced.
but then you also have to choose an address that isn't inside a range...
0xffff8400 is a good start, john is using 0xffff8480+, so maybe look at 0xffff8500...
Old May 19, 2009 | 11:33 PM
  #47
tephra's Avatar
half light, as in flashing on/off REALLY quick?
you are probably missing the main counting loop at the top (0->255)
Old May 19, 2009 | 11:44 PM
  #48
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Code:
sub_35500
00035500                 sts.l   pr, @-r15
00035502                 mov.l   r0, @-r15
00035504                 mov.l   r1, @-r15
00035506                 mov.l   r2, @-r15
00035508                 mov.l   @(h'80,pc), r1 ; FFFF8500
0003550A                 mov.b   @r1, r0
0003550C                 add     #1, r0
0003550E                 and     #h'FF, r0
00035510                 mov.b   r0, @r1
00035512                 mov.l   @(h'7C,pc), r1 ; FFFF8501
00035514                 mov.w   @r1, r0
00035516                 mov.w   @(h'88,pc), r2 ;h'15E
00035518                 cmp/hi  r2, r0
0003551A                 bf      35520
0003551C                 mov     #0, r0
0003551E                 mov.w   r0, @r1
00035520                 mov.l   @(h'70,pc), r0 ;  mut_9a
00035522                 mov.w   @r0, r0
00035524                 mov.l   @(h'70,pc), r1 ; FFFF8502
00035526                 mov.w   r0, @r1
00035528                 mov.w   @(h'70,pc), r0 ;  1
0003552A                 tst     r0, r0
0003552C                 bt      35548
0003552E                 mov.w   @(h'6C,pc), r0 ;  1
00035530                 mov.l   @(h'50,pc), r1 ; mut_26
00035532                 mov.w   @r1, r1
00035534                 cmp/hs  r0, r1
00035536                 bf      35548
00035538                 mov.w   @(h'64,pc), r0 ; h'140
0003553A                 mov.l   @(h'4C,pc), r1 ; load_2b
0003553C                 mov.w   @r1, r1
0003553E                 cmp/hs  r0, r1
00035540                 bf      35548
00035542                 mov.l   @(h'4C,pc), r1 ; FFFF8501
00035544                 mov.w   @(h'5A,pc), r0 ; h'15E
00035546                 mov.w   r0, @r1
00035548                 mov.l   @(h'44,pc), r1 ; FFFF8501
0003554A                 mov.w   @r1, r0
0003554C                 tst     r0, r0
0003554E                 bt      35554
00035550                 add     #-1, r0
00035552                 mov.w   r0, @r1
00035554                 tst     r0, r0
00035556                 bt      3556C
00035558                 mov.l   @(h'30,pc), r0 ; FFFF8500
0003555A                 mov.b   @r0, r0
0003555C                 shlr2   r0
0003555E                 shlr2   r0
00035560                 tst     #1, r0
00035562                 bf      3556C
00035564                 mov.l   @(h'30,pc), r1 ; FFFF8502
00035566                 mov.w   @r1, r0
00035568                 xor     #8, r0
0003556A                 mov.w   r0, @r1
0003556C                 mov.l   @r15+, r2
0003556E                 mov.l   @r15+, r1
00035570                 mov.l   @r15+, r0
00035572                 mov.l   @(h'C,pc), r0 ; sub A98A
00035574                 jsr     @r0 ; sub_A98A
00035576                 nop
00035578                 lds.l   @r15+, pr
0003557A                 rts
0003557C                 nop
Maybe I do not understand how it shall work but with engine off (not started) it shall not be lit according to code. Yes exactly rapid on/offs. So I have picked exactly the addresses you have suggested .
Old May 19, 2009 | 11:49 PM
  #49
tephra's Avatar
check out 0x35512...
you are loading an odd offset into r1, then doing a mov.w from it. so you are getting an alignment problem..
fix that up first
Old May 19, 2009 | 11:55 PM
  #50
acamus's Avatar
Oh, right, obvious bugs are always overlooked.
Thank you, you certainly deserve your GURU status
Old May 20, 2009 | 11:26 PM
  #51
acamus's Avatar
fix that up first
Dave I believe you are wrong here, the line @35512 is pretty legitimate according to manual:
MOV.W @(disp,PC),Rn
1001nnnndddddddd
(disp × 2 + PC) → Sign extension → Rn
so displacement (disp) can be odd...., this must be something else...
you can search h'7c in your rom and will find many mov commands.
Old May 20, 2009 | 11:29 PM
  #52
tephra's Avatar
its the mov.w @r1, r0 that im worried about.
its legal syntax, but i am pretty sure you will find that you are actually getting 0xffff8500 and 01, not 01 and 02 as you think.
it still needs to be word aligned...
Old May 21, 2009 | 12:57 AM
  #53
acamus's Avatar
I understand now the mistake, I am trying to use variables of byte size for word assignments . Thank you again.
Old May 21, 2009 | 01:52 AM
  #54
tephra's Avatar
ya
my mistake for not highlighting it properly!
Old May 21, 2009 | 11:12 PM
  #55
dude's Avatar
rte or rts?
NOP after jsr
Wow! What Rosetta Stone CD do I need to understand this language? I'm an Engineer and I don't understand any of this, though granted I only took VB and C++ and didn't enjoy either.
Keep up the good work guys, the more fellas we have attacking our ECU disasm, the more awesome our tuning platform becomes!
And Tephra, we need to get you another EVO!
Old May 21, 2009 | 11:13 PM
  #56
tephra's Avatar
hehe.
hightlight my sig hidden secrets :P (or just bad colouring on my behalf :P)
Old Mar 6, 2017 | 12:09 PM
  #57
sowne's Avatar
stupid question here, how realistic is it to disassemble rom without IDA? any free alternatives?
Old Mar 6, 2017 | 12:20 PM
  #58
logic's Avatar
Wow, old thread.
I wrote an SH2 disassembler in Python years ago, if it helps: https://github.com/logic/sh2dis
No support, and you're definitely on your own for working with the resulting output.
Old Mar 9, 2017 | 12:15 AM
  #59
pisyakot's Avatar
you can use GNU binutils or KPIT
jcsbanks
May 19, 2019 11:03 PM
Evo8life
Oct 28, 2017 10:02 PM
Zeno
13
Nov 25, 2016 08:55 AM
mykep83
Jul 9, 2016 09:29 AM
CaliMR
Apr 15, 2016 02:33 PM
