knock on light throttle spool up
Old Mar 18, 2009 | 08:04 PM
akauf's Avatar
my car has had low knock counts coming on at 2.5k to 3.25k or so since I've owned it. It will knock on spool up , ie getting on the throttle a bit for a hill or easing into wot or just stomping it at 3k. on the highway its the worst. ( I use the tephra cel flasher)
sounds like a boost leak, greddy valve the car came with was shot. so i put on a good valve, no change. Other than that, small leaks from the injector seals.
I've logged it and pulled timing in those areas, and no change. Logs all look the same. I'll get a log up here this week if I take the car out. I just installed my wide band and drove around the block. low tens when it knocks usually.
Any thoughts? a direction for me to head in when I start working on it next?
Old Mar 18, 2009 | 08:12 PM
WRC-LVR's Avatar
Is lean spool enabled ? Stock injectors and fuel pump ? Have you checked for exhaust touching anything esp cross braces ( false knock )
Also you have a 2003. Have the injectors been cleaned ( poor atomisation but then rich out the exhaust with unburnt fuel ) 10's are a little low. 11.2 -11.5 is much better
Post up your timing maps and AFR maps, along with logs including spool up from 2000 to 4500
Milburn
Old Mar 18, 2009 | 08:21 PM
akauf's Avatar
My dp indeed does touch the cross brace, it rattles when taking off from a stop sometimes.
Stock injectors have never been removed. PTE 1000ccs are on the way. It has a single wally in it which , on a side note, I believe sounds weird. ( more than whines).
any parts installed while I've owned it have had no apparent effects on the knock. ( I don't drive the car more than around the block here and there til I get all my parts on)
I'll pull my rom and get some logs on here tomorrow.
Old Mar 20, 2009 | 08:47 PM
C6C6CH3vo's Avatar
WOT usually exterminates any part throttle knock.
EvilDSM97
Aug 29, 2022 09:02 AM
Ferp
Mar 11, 2017 09:50 AM
hattackk
Nov 18, 2015 06:15 AM
740 Turbo Brick
Oct 21, 2015 05:32 PM
ehall20
Apr 5, 2014 05:26 PM
