EvoScan2.6 and Tech Edge 2J1 WBo2
Old Mar 19, 2009 | 08:01 AM
GiGas's Avatar
Well I have a TechEdge 2J1 WideBand o2 sensor controler and would like to log readings into my EvoScan2.6.
You can see it here: http://wbo2.com/2j/default.htm
It provide both RS232 and a analog output.
Where can I read info about this? how does the Innovates system interface EvoScan?
Thanks GiGas
Old Mar 28, 2009 | 01:55 PM
autoxer_minh's Avatar
I have an AEM UEGO sensor that I'm logging with EvoScan v2.5. I've had problems logging it with v2.6 beta 8 so I can't offer any help there. I'm using the RS232 output connected to an actual DB9 serial port on my computer, not through a serial-usb converter that some people have trouble with. Are you able to get RS232 data using Hyperterm? If so, you might want to try setting up EvoScan to log it as an AEM WB. Sorry, I don't have any experience with Innovate's WB.
Old Mar 28, 2009 | 03:58 PM
Fast_Freddie's Avatar
Veteran: Navy
It uses a 0-5v analog serial output like the AEM UEGO. Hook the RS232 up to the computer using the serial port or a usb to serial converter and make sure which ever you choose, set that COM PORT to 1-3. Go into evoscan and select the AEM wideband and then select the correct COM PORT that you set it up on... try that and report back...
Old Mar 29, 2009 | 02:42 PM
kkarim's Avatar
your best bet would be to disable the rear o2 sensor, and log the analog voltage through it's acd input.
there are a bunch of other free adc inputs you can log with.
3VOLUTIONIST
May 13, 2017 01:12 AM
eazlan
May 7, 2017 01:30 AM
mines5
Oct 8, 2016 11:28 PM
babaz7
Mar 10, 2016 07:17 PM
GiGas
Nov 10, 2015 04:29 AM
