Evo live map source
Old Mar 22, 2009 | 05:28 AM
leecavturbo's Avatar
this is not an executable pc app then john?
just extracted it and no installer/run ?
so does it hash in with ecuflash somehow?
Old Mar 22, 2009 | 05:46 AM
MR Turco's Avatar
Originally Posted by jcsbanks
Given that there is a 12k block available in the 9 we could put nearly every map and its axes into RAM, changing the vectors in the ROM is not so bad. However, the job of adding all the editing to the PC app is huge.
I can't imagine needing every table in the app - i think you mentioned that before. I think what you have so far along with Inj Latency and basline wgdc would be beneficial. I also think having the map tracer on all the tables would be clutch.
If someone who really knows what they are doing could make the app have a "Table adder" feature that could be even better. The user could create the table size, enter the addresses needed and it will auto populate a tab page with the table. Obviously i have no idea how difficult that is but it might be something to consider.
For logging the DMA has incredible resolution. I would say the logging could use the current reading displayed. It would also be really nice if the csv file was saved in Evoscan format so it could be easily opened and evoscan features could be utilized.
These are all suggestions. I have no idea of the scope of complexity nor am i trying to come off as complaining of the current version. I would/will continue to use this version if it was never changed. I just need to make the harness or wait for the button that allows me to switch maps
Old Mar 22, 2009 | 06:15 AM
jcsbanks's Avatar
leecavturbo, this is the source, but you can run the exe from the debug folder. The exe and xmls are bundled with each ROM.
MR Turco, yes the logs could be written in Evoscan format if we sorted out the time columns.
Also we should make a smaller MUT table with all the stuff to log in one block.
Old Mar 22, 2009 | 08:10 AM
andrewzaragoza's Avatar
had a little while to test it yesterday. tested the basics and it seems to be working fine using the release from the other thread. i tried using the source code i noticed that the knock trace is not working properly on the source code. i will try again later in debug mode to see what is going on.
Old Mar 22, 2009 | 08:47 AM
jcsbanks's Avatar
xmls are different for each ROM, the one in this thread is 88570008, so the logging address on the front page is different. The source is the same.
Old Mar 22, 2009 | 11:13 AM
Ok. thanks. ill get the xml from the other thread and do some testings later. simple read & write on the alt maps work fine. are u planning on just using the alt maps or will u include the base maps as well?
Old Mar 22, 2009 | 12:20 PM
jcsbanks's Avatar
Thanks for the testing.
So far it has been only the alt maps. When the ECU is powered up for the first time or after reflashing, it copies all the alt maps in a block from ROM to RAM. Tephra had (by convenient accident I think) put all the alt maps in a block except for the injector size which he moved on request.
We could move pointers and headers/maps from all over the place into RAM, not just the alt maps, but I didn't want to confuse at this stage.
Old Mar 22, 2009 | 01:41 PM
codgi's Avatar
Anyone got any ideas how to make all the mapping tables configurable through xml like Ecuflash? Presently I add datagridview, bindingsource, buttons and code for each different type of map and just use xml to store table sizes.
Will look into it once I get a chance to look at the code. But it shouldn't be too bad, just a matter of seeing where/how you've hardcoded it and figuring out how to make that code more generic.
Work + new house has me busy so if there any CS/SE/SD college kids with nothing to do in their dorms and want to use those courses they have been taking <hint><hint> .
Old Mar 23, 2009 | 04:01 AM
MR Turco's Avatar
John, would it be beneficial or possible to have a button that resets LTFTs?
Old Mar 23, 2009 | 06:51 AM
logic's Avatar
You IX guys can easily reset fuel trims just by reflashing; us VIII guys have to pull power from the ECU to do it.
I wonder how difficult it would be to reset the fuel trims on a map switch? It would seem like a good time to do it, given that you're indicating that you're making a major fuel change.
Old Mar 23, 2009 | 07:16 AM
jcsbanks's Avatar
One worry I have about the VIII with it not resetting fuel trims is that a reflash leaves junk in the RAM. Tephra's code checks for 0xDEAD and if not found he resets his variables, I'm piggybacking onto this as my signal to copy ROM to RAM. I just hope that this method is reliable, otherwise 0xDEAD might still be there in one RAM area but the maps have been trashed, this would need a cold reset after flashing or another method. We'll find out when we test - I've done 8 MR JDM and will test tomorrow hopefully.
Old Mar 23, 2009 | 07:19 AM
MR Turco's Avatar
Yeah but does it reset the trims when you flash live? If i make a change to injector size i would want to get the trims back to 0 instead of waiting for them to cycle
Old Mar 23, 2009 | 07:46 AM
noticed its the blockaddress.xml that contains the addresses and is the difference between ecu ids. btw i noticed that your baud rate on the vid is 38400 and the default 15625. i tried changing the baud rate to the same value as yours but i had an error. i'll debug later and see where it was breaking.
Old Mar 23, 2009 | 07:50 AM
jcsbanks's Avatar
I use 38400 on my personal car as this is faster and also is a nice rate for my Pocket PC to log at on its native serial port (I change the ECU's baud rate to match, but it means a dealer MUT would not connect to my ECU). Apart from the source, all releases should have 15625.
Old Mar 23, 2009 | 12:03 PM
jcsbanks's Avatar
I've started a new thread about the Evo 8 RAM clear problem since it is related more to ECU code rather than the PC application.
