Any ACD/AYC evoscan logging experience?
my cable is a Tactrix modified as per your instructions (pin9, pin 1,...) on your website
I would definitively buy a Limitless one if it was solving the problem but as Kikiturbo has problem with his Limitless cable
the strange issue is that Evoscan (2.5 or 2.6beta 's) DO connect with the AYC ecu : the log windows turn to green , but then the logged dat's are weird.
And for the actuator on/off , Evoscan DO NOT connect and retries forever
if it helps I can send you some screen capture and/or logs or possibly take some 'debug' files with a specially modified Evoscan
I have the Limitless cable and my car has ACD+AYC, I will see if I can log something on the way to work. I am pretty sure I have logged with it before, but I could be mistaken. Low priority for me too.
The last post in this discussion seems to say no
https://www.evolutionm.net/forums/ec...pinouts-3.html
Brings charting of logs into a whole new dimension.
