How does one log load accurately?
Old Mar 31, 2009 | 05:22 PM
C130flyer's Avatar
Forgive me if this has already been asked but I searched and searched and searched and didn't pull up anything.
What is the most accurate way to log load using Evoscan? How do I do it?
Keep in mind that I would like to learn how to log load in order to know which map point to modify in Ecuflash.
Whoever answers this question for me accurately, will be compensated to the tune of 20 bucks over paypal.
Thank you for your time,
Rob@modularturbo.com
Old Mar 31, 2009 | 05:55 PM
tephra's Avatar
Rob,
There are at least 3 ways to log load:
1) calculated load, obviously the quickest, but not the most accurate. As the name suggests its "calculated" from other parameters, IPW, injectorscaling, rpm etc etc
2) 2byte load, requires setting up your MUT table with the appropriate memory locations - Look for the "2byte" thread. This will give you a better load, although not 100% (as different routines use different compensated (temp/baro) loads)... Also 2byte load has a problem is High/Low byte mismatch, which results in weird peaks/throughs in the logs.
3) 1byte load, in TephraMod V5.10. Same deal as #2 but doesn't have the problem of high/low byte mismatch.. Also its only 1 byte so its twice as fast as 2byte load.
HTH's
D.
Old Mar 31, 2009 | 08:12 PM
C130flyer's Avatar
Very cool Tephra thank you.
My question is how do I do it?
My ROM ID is 96420008
Old Mar 31, 2009 | 08:14 PM
tephra's Avatar
search for the 2byte thread... Jack_of_trades is the author.
make sure you have the MUT_TABLE defined in your ecuflash - if not define it (2byte thread should have help there)
change the MUT entries for 00 and 01 (or 02 and 03 - whatever evoscan is using) to the 2byte load from the afore mentioned thread
flash+log..
Old Apr 1, 2009 | 05:23 PM
C130flyer's Avatar
Im gonna try it tonight thanks bud.
Old Apr 1, 2009 | 08:52 PM
C130flyer's Avatar
worked like a charm!
Tephra ROCKS!!!!!!!!!!!!!
Old Apr 1, 2009 | 08:56 PM
tephra's Avatar
glad you worked it out.
did you end up going with 2byte load or 1byte tephramod?
Old Apr 1, 2009 | 09:05 PM
oldevodude's Avatar
Sounds like 20 bucks goes to Tephra
Old Apr 1, 2009 | 10:08 PM
C130flyer's Avatar
2 byte
I tried doing the The "Tephra mod" but I couldn't get it to work.
I haven't tried 1 byte yet.
Old Apr 1, 2009 | 10:09 PM
C130flyer's Avatar
tephra whats your paypal email I'm gonna donate 20 bucks to the Tephra fund
Old Apr 1, 2009 | 10:10 PM
tephra's Avatar
donations@globalshare.net
um tephramod includes 1byte, you cant do 1byte without tephramod
what didn't work?
Old Apr 1, 2009 | 10:21 PM
C130flyer's Avatar
IDK I flashed it after adding it to the XML then tried it, no joy.
It was a half hearted attempt though, I'm sure its user error LOL.
paypal payment sent by the way.
Old Apr 1, 2009 | 10:31 PM
tephra's Avatar
cool.
well you need to change the immobiliser and stuff like that...
its not too hard
Old Apr 6, 2009 | 02:42 PM
EnjoyDriving's Avatar
I have evoscan 2.5 and I was able to log the "2bytes Load", but I didn't see the "1byte load" in the list for logging...amd I missing something? Or, is it labelled differently??
Old Apr 6, 2009 | 04:22 PM
tephra's Avatar
1byte load is a tephramod option.
you need to be using a tephramod rom to use it
you also need to add the xml manually to evoscan to see the item to log.
