need a tune
Old Apr 5, 2009 | 08:23 AM
MIVEC 4G63's Avatar
need a tune
hi guys i have tried so many things and still not able to see full boost. timing is on point and don't have leaks in the system, just put in same 272s with a 10.5 lift from BC on my IX with your common 3in full exhaust o2 and all, no cat, apex intake fuel pump mbc lower ic pipe and stock injectors. im throwing a check eng light and code if for cam sensor circuit, im told one last option is to tune it. im trying to practice on my car but i need something to start with. i have the ecuflash, does anyone a map they can send me?
Old Apr 5, 2009 | 03:50 PM
G20's Avatar
G20
you need a specific tune for the car. Any blindly map that you may use can do more harm than good. If the code is about cam sensor circuit then it may be cam installation error too. Your car is running leaner than before those mods now as well.
Old Apr 5, 2009 | 08:07 PM
06RedRalli's Avatar
Check your cam position sensor.
Old Apr 6, 2009 | 07:12 PM
MIVEC 4G63's Avatar
i checked it and it looks fine
Old Apr 6, 2009 | 07:16 PM
Wicked E's Avatar
We've been telling you MULTIPLE times in your other threads about this issue that your cam trigger is 180* out. It can LOOK fine but may actually not be fine.
Tuning will not help you with this situation.
-E
Old Apr 6, 2009 | 07:17 PM
mixmastermatt's Avatar
You probably put the cam sensor trigger back on 180 degrees out, which is causing your CEL and misfires.
