1.29 vs. 1.41 trouble shooting
Old Apr 3, 2009 | 10:20 AM
oneguy's Avatar
I was using Ecuflash 1.29 with the 1.3 tactrix cable and all was going well. I decide to try out 1.41 and I can flash fine, but now I have an SES light on. When I use the Display DTC function on Evoscan v2.1 after I flash with v1.29 I get a "Evo4 Diagnostic Codes: knock sensor". When I do the same scan after a flash with v1.41 I get: "Evo4 Diagnostic Codes:No Evo4 Diagnostic Trouble Codes Present."
I know Ecuflash v1.41 adds some knock tables that weren't editable in v1.29 so I was thinking the issue may the issue is stemming from that? By the was I have rom v88590015.
Anyone have any ideas?
Old Apr 3, 2009 | 10:27 AM
rolly1818's Avatar
Registered User
i want to go to 1,41 as well but it keeps saying i need service Pack 3..lol
check the page where u downloaded ecuflash it has a description of the changes.
Old Apr 3, 2009 | 10:53 AM
oneguy's Avatar
Yeah I checked the openecu.org list of updates (via Ctrl F). I found nothing when I searched for knock.
Old Apr 3, 2009 | 01:05 PM
logic's Avatar
Upgrading EcuFlash doesn't change your ROM image, it just adjusts what you have the ability to change.
Older versions of EvoScan were notorious for not reading DTCs correctly; you might want to get upgraded to 2.5, or try Scantech instead.
Old Apr 4, 2009 | 08:01 AM
oneguy's Avatar
Yeah I tried the display dtc function with Evoscan 2.5 but I get an error everytime. Logging with 2.5 works fine though so I am no sure what the fault lies with that one.
I am going to give scantech a try.
Old Apr 5, 2009 | 06:37 PM
oneguy's Avatar
I need to mess around with scantech tomorrow but I tried to read with an accutron at advanced auto parts and it kept giving me an error so i am not sure scantech will yield anything better.
Old Apr 5, 2009 | 11:14 PM
oneguy's Avatar
I have tried a variety of different things to get scantech to work it still wont connect
with Evoscan 2.5 this is what I get:
Info: Initialize Vehicle ECU...
Info: OBDII ISO Init...
Info: Waiting for vehicle ecu...
Info: Initializing At 5 baud...
Info: Initialization Complete...
Error: No Response from Vehicle ECU
Info: Check DTCs Complete.
I am all out of ideas. I can data log fine and since the car runs properly after flashing i am assuming the cable is fine (i flashed back to stock then reflashed back to current)
all of this started after my second time flashing using Ecuflash 1.41. The only thing I changed with that flash was I pulled one degree of timing in 3 cells. All of my other flashes with 1.29 never yielded any ill results. My most recent mod has been the Evo X Map sensor which I did a day or two prior to the flashing.
Any help would be greatly appreciated.
Old Apr 6, 2009 | 07:03 AM
mrfred's Avatar
Try flashing in the previous ROM, and then reflashing again to your updated ROM.
Old Apr 6, 2009 | 07:16 AM
oneguy's Avatar
ok, i will go out and try it and see what happens
I don't know if this helps but:
I know evoscan 2.1 is not known to be accurate for DTC's but this is what it gives me:
Updated: 09:49:26
Evo4 Diagnostic Codes:Barometric pressure sensor
Knock sensor
Updated: 09:49:58
Evo4 Diagnostic Codes:Vehicle speed sensor
Knock sensor
EGR sensor
Updated: 09:50:37
Evo4 Diagnostic Codes:Injector circuit
Updated: 09:50:53
Evo4 Diagnostic Codes:Knock sensor
Fuel pump relay
Old Apr 6, 2009 | 07:31 AM
oneguy's Avatar
I tried the reflash back to the previous and then the current. Still same results: No CEL on initial startup, i shut the car off and start it up again and the CEL reappears.
My dad was thinking it could be a arcing from a spark plug wire to the engine causing random codes the be thrown but I can't investigate this until it gets dark.
Old Apr 6, 2009 | 12:03 PM
oneguy's Avatar
Could a bad MAP sensor be causing the ECU error that I can't read?
Old Apr 6, 2009 | 01:17 PM
mrfred's Avatar
Nope. You'll just get a MAP sensor CEL.
Old Apr 6, 2009 | 07:27 PM
oneguy's Avatar
Here is my modified xml file. It has the JDM MAP and 2-byte load additions. Does this look right?
I am trying to figure out if the error is my own. I can post the rom too if that will help.
File Type: txt
Old Apr 7, 2009 | 04:56 AM
oneguy's Avatar
Bump
What would cause the CEL to go off but the codes to not be readable?
Old Apr 7, 2009 | 06:32 AM
mrfred's Avatar
Bump
The problem that you're having is very strange. You can flash the ECU, but every OBD-II scanner that you've tried to use will not connect? Or is it that the scanner can connect but gives no OBD-II code?
