Starting over with ECUflash and Evoscan
Old Apr 5, 2009 | 10:01 AM
mountainturbo's Avatar
So the computer I use for tuning bit the dust the other day, and I need to go out and get a good tune into my car.
My question is this: I had the original version of ECUFlash and an oooold version of Evoscan on that computer. When I install the new versions of both, will I still need to go through all the same steps I did with the old ones? I.E. edit the data.xml etc for 2 byte load, edit evoscan for reading the JDM map sensor, edit to remove the rear 02, etc?
That was a lot of work and I don't remember everything I had done. God I hate it when technology bites the dust! (And go figure that was the one thing I didn't get backed up was all my tuning stuff).
Old Apr 5, 2009 | 10:30 AM
G20's Avatar
G20
if you can get those configuration and definition files off your old machine and copy them over your new one then it'll save you some works.
