Rich AFR's after shifting to next gear.
Old Apr 15, 2009 | 11:15 AM
Nissan2Evo's Avatar
I tried searching with all the possible combination of terms for information on this but couldn't come up with much. Hopefully we can get some helpful info, links in here.
Anyhow, I did a bit of logging and testing while tuning a friends car the other night. After setting the boost levels and moving onto the AFR's...I was able to get a nice sweet 11.3-11.1 AFR curve under full boost during 3rd gear pulls.
Being familiar with the ECU's rich after shift changes, I logged a 2nd-3rd gear pull. 2nd gear AFR's were in the 11.6-11.4's...with 3rd gear seeing a whole point richer than before...mid-low 10's. Car pulled great, no knock..timing advancement where I needed it. Went ahead and did another 3rd gear pull to see if it would be the same as before, sure enough 11.3-11.1's.
Is there a cure for this in an effort to extract some more power without leaning out the target AFR tables while tuning in 3rd gear and aside from going EMS?
Lean spool is enabled on this car like stock.
Thanks!
Jorge R.
Old Apr 15, 2009 | 12:01 PM
jcsbanks's Avatar
Disable lean spool if you don't like this, or if you want to use lean spool and have good gas, run 12:1 on your first pull that will richen as you drive it harder.
Old Apr 15, 2009 | 04:31 PM
tephra's Avatar
does he have an atmo bov?
otherwise its probably the low load high rpm part of the table that is too rich.
Old Apr 15, 2009 | 04:58 PM
GST Motorsports's Avatar
lean spool
Old Apr 15, 2009 | 05:19 PM
Murf's Avatar
we shoot for around 12.0 to 11.9 in 3rd 4th will usually drops right where we want it.
Old Apr 17, 2009 | 04:45 PM
Evoryder's Avatar
lean spool and tune for the load areas where you get back on the throttle.
Old Jun 12, 2009 | 07:20 PM
mt057's Avatar
Sorry to be redundant but disalbeing lean spool will help prevent afrs from getting richer as you enter the next gear?
Old Jun 14, 2009 | 03:09 PM
R/TErnie's Avatar
bump for an answer to the question above.
Old Jun 14, 2009 | 07:13 PM
house_of_senate's Avatar
Yes
Old Jun 14, 2009 | 07:15 PM
R/TErnie's Avatar
Thank you.
Old Jun 16, 2009 | 03:12 PM
Oracle1's Avatar
What else does leanspool do besides richen up AFRS? Whats the purpose of making it richer?
Old Jun 17, 2009 | 05:28 AM
daymean's Avatar
^^^ leanspool richens up the AFR to allow the engine to run cooler and be more knock resistant.
Old Jun 17, 2009 | 07:53 AM
Fast_Freddie's Avatar
Veteran: Navy
It is routine I suspect Mitsu used to make the factory tunes more reliable for a wide range of enviornments, for people that don't go out and log their car daily...
Eisen7
Nov 10, 2015 01:51 PM
BillCosbysPudding
Jan 31, 2012 04:20 PM
def1
Sep 30, 2010 09:20 PM
kouzman
Dec 31, 2009 01:09 PM
David Buschur
909
Jun 22, 2008 06:20 AM
