stationary rev limiter
Old Apr 21, 2009 | 09:59 AM
evo8330's Avatar
how can i activate the stationary rev limiter? i try the search function but dont find that i search...
my rom are the 96530006. on ecuflash is set to 5000rpm but dont work
thanks andy
Old Apr 21, 2009 | 10:11 AM
SEEnoEVO's Avatar
Are you putting the car in gear, at a stop, clutch in, and holding down the gas?
Old Apr 21, 2009 | 10:12 AM
newimportowner's Avatar
Do you have an 03 EVO 8 by chance?
Old Apr 21, 2009 | 10:23 AM
evo8330's Avatar
no its a 04 EDM gsr.
the stationary rev limiter dont work... i put the clutch and the acceleration pedal... is possible that is dissactivate?!
Old Apr 21, 2009 | 12:54 PM
nonschlont's Avatar
On my usdm stock launch control is 5000. When you have the clutch in, then put it in 1st gear, and slowly hit the gas to reach the set rpm, (you can actually pass it, if you just WOT) it should hold the rpm's at the set rpm, once you can tell the 2 step in activated, then press the throttle 100% WOT, the feather the clutch, quickly, but dont dump it either.
And if thats doesnt do it, then somethings up..
Old Apr 21, 2009 | 05:25 PM
Kracka's Avatar
Make sure your car is sitting perfectly still and not rolling at all.
Old Apr 21, 2009 | 05:39 PM
Crazy K's Avatar
everyones right, make sure your at a complete stop and I like to blip the throttle up to around 5700rpm which is where mine is set, also pull your ecu rom and make sure your stationary rev is set to whatever you want, on my 03 usdm it was set at like 7600rpm from the factory
Old Apr 22, 2009 | 04:12 AM
evo8330's Avatar
my stationary rev limiter is set from factory to 5000rpm..
tomorow try again...
Old Apr 25, 2009 | 05:00 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
a mini thread jack but what is the procedure to enable the 2-step on a 04 evo 8 usdm
Old Apr 25, 2009 | 09:56 PM
SLO-EVO's Avatar
make sure that youve enabled the feature, then just open it and set it to what you want to launch at.
blitzkreig
Jun 20, 2016 10:35 AM
jdbigz
Apr 10, 2015 04:23 AM
Sodré
Aug 5, 2007 08:27 AM
Evo_Pma
Jul 6, 2007 09:32 AM
mercedevo
May 17, 2006 08:53 PM
