HELP!!!!! 3 port GM boost solenoid
Old Apr 27, 2009 | 04:56 PM
808boost's Avatar
Need install info on GM boost solenoid with extenal wastegate. tryed to tune with my wastegate duty cycle set at 0 and i was still spiking out. all my vacume lines are place as directed but stillnot able to figure it out. i searched the forums but was not able to find anything using extrernal wastegate. any help will be great.
Old Apr 27, 2009 | 06:14 PM
mplspilot's Avatar
On the side of the solenoid that has 2 ports, one to intake/atmosphere and the other to WG — switch those 2 around and see if it helps.
Old Apr 27, 2009 | 06:37 PM
808boost's Avatar
ok ill try it
Old May 5, 2009 | 07:24 PM
808boost's Avatar
i figured it out and now need a better solenoid maxed out the GM solenoid
Old May 5, 2009 | 07:57 PM
andrewzaragoza's Avatar
if that is the case you might need a stiffer wastegate spring. also check for boost leaks.
Old May 5, 2009 | 08:14 PM
fjo_newport's Avatar
For a dual port external WG you should:
1) Run a boost source to the lower port.
2) Run the NC (normal closed) port of the GM solenoid to the top port.
100% Duty Cycle = Closed WG, full boost
0% Duty Cycle = Spring pressure
Old May 5, 2009 | 11:22 PM
GST Motorsports's Avatar
Are you running 40psi or something?
Old May 6, 2009 | 06:50 AM
GTODesign's Avatar
I use a Perrin BCS with a Tial 44mm / T04Z - 15psi spring running 35psi at the manifold.
Loop the BCS in the same way as you would a regular internal style wastegate and you should get good resolution and control.
Old May 6, 2009 | 08:14 AM
fostytou's Avatar
EvoM Community Team
That doesn't make any sense, I think something is wrong with your setup...
deeman101
Jun 5, 2012 07:03 PM
Kierkegaard
Nov 24, 2009 09:59 PM
Kracka
Mar 5, 2009 07:59 AM
pjb00stin
Jul 7, 2008 05:13 PM
dudical26
Aug 15, 2007 11:39 AM
