Maf Scaling Offset Address for 9417008
I'm not sure if this is what you need..this is my 008 xml you may find it here.
https://www.evolutionm.net/forums/ec...70008-xml.html
The Evo IX has a MAF scaling offset, much like the Boost Control Load Offset (BCLO). The Boost Desired Engine Load (BDEL) only goes from 0 - 159 so you need to use the BCLO to use values higher than 159.
The MAF Offset does the same thing, allowing you to use higher MAF scaling values. At least it does on the 9's.
He wants to know if the VIII's have this, and if so, if anyone has the address for it.
