Hard Starting with New Injectors
Old Jun 22, 2009 | 01:56 PM
  #31
GST Motorsports's Avatar
Originally Posted by cmj
4.69 3.312
7.03 2.184
9.38 1.560
11.72 .912
14.06 .696
16.41 .312
18.68 .240
Also this car is using FP's new 80mm intake pipe along with the 80mm Red and FP4R cams. The intake is connected to the stock box at the moment.
So have you rescaled your MAF for the intake pipe? What are your current fuel trims?
What settings do you have in the IPW adder table?
Old Jun 22, 2009 | 02:26 PM
  #32
cmj's Avatar
cmj
IPW ms:
226.3
108.1
46.1
17.3
8.6
6.9
3.7
1.7
1.7
The injectors are scaled to 914. Fuel trims after 1 hour of stop and go traffic are:
Low LTFT=3.042
Mid ltft= 1.47
STFT Jumps around between 0-8.
Old Jun 22, 2009 | 02:30 PM
  #33
IPW ms:
226.3
108.1
46.1
17.3
8.6
6.9
3.7
1.7
1.7
Low LTFT=3.042
Mid ltft= 1.47
Try changing the 1.7's to 0's and half the 3.7 and 6.7, change the 8.6 to 6 and the 17.3 to 13
Also try adding a little latency at 14v
When you are having the warm start issue, if you put the pedal to the floor, does it then start right up?
Old Jun 22, 2009 | 02:38 PM
  #34
cmj's Avatar
cmj
It will not start unless I put the pedal to the floor, even then it takes a while.
Old Jun 22, 2009 | 02:44 PM
  #35
TurboTylerIX's Avatar
same here! FIC 1250's though... i even zeroed the IPW like you suggested GST.
Old Jun 22, 2009 | 02:45 PM
  #36
Ok try pulling out a bunch of IPW at warmer water temps and see if it gets better.
Old Jun 22, 2009 | 04:50 PM
  #37
cmj's Avatar
cmj
I'll give that a try tonight. BTW, I have not touched the MAF scalling tables.
Old Jun 22, 2009 | 08:29 PM
  #38
cmj's Avatar
cmj
I had to zero out the IPW from 20c on up to get the car to start without throttle input. It seems to be good now.
Old Jun 22, 2009 | 09:42 PM
  #39
Glad you got it figured out. The larger injectors usually need the IPW table tweaked.
Fast_Freddie
Oct 30, 2023 01:56 AM
Kaveeth
Oct 27, 2014 05:47 PM
Green_Bandit
Lancer Engine Management / Tuning Forums
Jun 19, 2013 04:39 PM
AlwaysinBoost
Sep 23, 2010 12:30 PM
