Hard Starting with New Injectors
I have read mrfreds thread about all his issues with his FIC 1050's....
https://www.evolutionm.net/forums/ec...-question.html
same problems here... the thread really never said if/how he fixed the warm start issue...
Alternative fuel subforums here:
https://www.evolutionm.net/forums/alternative-fuel-225/
thread here
https://www.evolutionm.net/forums/al...-ones-e85.html
thread here
I am still having warm start problems. I have messed with IPW adder table... i have even zeroed it out at the warm temps and it did not change anything. I have played a little with ISC steps with no success.
There has got to be a table that i cannot access that controls startup IPW. you can see in my log of a startup that my initial pulse is 12ms which is probably flooding it. since i have zeroed the IPW adder table, i cant get it any lower without some other table.
Has anybody ever removed the intake manifold and cleaned as well as cleaning the intake ports to the cylinder (with the head on the car). Brass toothbrush, seafoam, ATF, whatever works for you.
Yup
7.03 2.184
9.38 1.560
11.72 .912
14.06 .696
16.41 .312
18.68 .240
Also this car is using FP's new 80mm intake pipe along with the 80mm Red and FP4R cams. The intake is connected to the stock box at the moment.
