so ... Lets play wont my car start???
Old May 6, 2009 | 11:16 AM
nonschlont's Avatar
so ... Lets play Y wont my car start???
so I took my kitty to get nuetered, and as I was getting back in the car to go, the car wouldnt start normally... It turned over car seemed fine, I said IDK... I come home, get ready to go to work and the car wont start!!! Then it started, then died out... I have no clue!
ANY IDEAS...
Old May 6, 2009 | 11:18 AM
RoadSpike's Avatar
I suppose you've checked both fuse compartments?
Any codes?
Old May 6, 2009 | 11:20 AM
nonschlont's Avatar
Any codes?
nope. Im unsure what to look for, besides battery/starter... And no codes...
Old May 6, 2009 | 11:27 AM
rolly1818's Avatar
Registered User
check your fuel system.
Old May 6, 2009 | 11:35 AM
nonschlont's Avatar
I have given the motor a quick once over, and nothing seems to catch my eye, but thats not saying much! The injectors/fuel rail arent leaking, if thats what you mean...
Old May 6, 2009 | 11:37 AM
nonschlont's Avatar
Any codes?
would you be able to tell if a fuse was blown, just by looking at it, or am I gonna have to pull all of them out? sorry for the dumb question, I know, but when it comes to mechanics, I guess Im dumb.
rolly1818's Avatar
Registered User
injectors may be fine, but is ur fuel pump coming on, on ignition?
any lines damaged? fuel filter clogged?
if its not electrical it can only be fuel or spark really (dont flame me i am being general)
check for continuity across the fuses, any electrician should be able to do it.
Old May 6, 2009 | 11:47 AM
nonschlont's Avatar
unfortuneately for me, this is a lil beyond my knowledge of cars, which is obviously limited. How can you check/tell if the pump is coming on during ignition? Nothing appears to be damaged... Where is the fuel filter located?
I wouldnt flame you, I really appreciate the input, as Im sitting in my garage waiting for some help from a friend.
Old May 6, 2009 | 12:02 PM
rolly1818's Avatar
Registered User
not certain about the fuel filter (don't even know if the evo has one lol),.
turn on the ignition and u should hear a humming sound where u put in ur fuel pump (behind ur drivers seat). should be pretty easy to hear. the other thing is it may be coming on but the fuel filter in your tank maybe clogged.....
Old May 6, 2009 | 12:06 PM
Bggstin's Avatar
Ok. Simple solution that works 90% of the time. Pull a plug and see if theres spark. If there is then it's a fuel problem. If it doesn't spark it's electrical. Then go from there.
Old May 6, 2009 | 12:08 PM
nonschlont's Avatar
Ive never heard my fuel pump wine. Lots of ppl complain about that, but Ive never even heard mine... not once. Been in for ~ 2 years. I was thinking that was a good thing...
Old May 6, 2009 | 12:11 PM
rolly1818's Avatar
Registered User
i am going on the assumption that his car can start or did start so there was spark. now he is not getting fuel or there is an electrical problem.
still try to see if u get a spark, then u can narrow down the problem.
u should hear a wine..put ur ear down and listen lol
Old May 6, 2009 | 12:12 PM
nonschlont's Avatar
I have a friend on the way to help out... Im gonna start w/ the battery, and go from there. Will try this if its not the battery...
When you pull a plug, Im assuming I should then try to start the car? Just wanna make sure.
Thanks for the input guys.
Old May 6, 2009 | 12:36 PM
nothere's Avatar
what you are looking for is the arc when the plug is firing. leave the plug on the ignition wire/boot and crank. watch the gap of the plug.
Old May 6, 2009 | 12:40 PM
nonschlont's Avatar
oic that makes more sense.
