Need help switching 94170008 to 94170015
Old May 15, 2009 | 03:50 PM
wtf_is_a_evo's Avatar
Ok im switching so i can use tephramod v5.10
I know about switching the maps but one thing i got hung up on is
air temperature compensation
on the 0008 im showing
(degrees is on the left side) and (units are on the right side)
0008 rom
-32 - 79
-8 - 69
7 - 59
20 - 53
34 - 48
50 - 44
77 - 40
82 - 33
0015 rom
-32 - 79
-8 - 69
7 - 59
13 - 54
20 - 49
27 - 45
34 - 41
41 - 34
Now my question is do i copy both sides and past over the 0015 rom? this is what it looks like
there are a few other tables just like that i will skip them and not flash till im 100% sure what to do thank you in advance.
Old May 17, 2009 | 03:09 PM
Appauldd's Avatar
Where are you located in KY?
If you are near Cincy....I can give you a hand.
Old May 17, 2009 | 04:27 PM
tephra's Avatar
if that map in the 94170008 rom is stock, then leave it stock in 94170015...
probably a defn problem...
Old May 17, 2009 | 07:21 PM
Its not stock i had someone tune it. Since im learning how to tune should i just start new and change stuff my self?
also i live in mt sterling about 30 mins away from lexington
Old May 17, 2009 | 07:25 PM
tephra's Avatar
ok you will have to spend a bit more time flapping about then.
get a KNOWN stock ROM (for 0008) and compare that to YOUR 0008 ROM, any maps that are the same DONT need to be copied to the 0015 rom..
get it?
Old May 17, 2009 | 07:31 PM
Yes i think i got it
If anyone has a stock 0008 rom by any chance can you please put it up so i Download it and compair it to mine?
again thank you for the advice
Old May 17, 2009 | 07:35 PM
tephra's Avatar
can check out aktivematrix.com - otherwise pm me your email and ill send you one..
Old May 17, 2009 | 07:37 PM
ok ill look on there and ill get back to you if i cant seem to find one.
Old May 17, 2009 | 07:41 PM
Ok i have a stock 0008 rom gonna take a look and compair ill be back with some more info. shortly
Old May 17, 2009 | 08:13 PM
Well i made it to air temp compensation and the stock rom compaired to mine
mine on the left and stock evo 8 rom on the right(the left values are the same but the right ones go off by one at the bottom so should i copy the left values and the right values to the 0015 rom?
-32 79____ -23 79
-8 69____ -8 69
7 59____ 7 59
20 53____ 20 54
34 48____ 34 49
50 44____ 50 45
77 40____ 77 41
82 33____ 82 34
I just dont understand why the left values are changed from the 0008 and 0015
list of other tables that have the left values diffrent from 0008 to 0015
1.knock filter map 1 (timing)
2.desired idle rpm neutral (idle)
3.desired idle rpm drive (idle)
came across the boost cut table and found this value on the 0008 (1631950) MS
Last problem i found was the boost limit table on the 0015 rom from v5.10TephraMOD link
looked like this
250____230
281____230
312____225
2559...____225
1362...____225
2559...____225
1362...____225
43____225
1151...____225
Old May 18, 2009 | 05:21 PM
bump
Old May 18, 2009 | 06:11 PM
Appauldd's Avatar
Use the air temp trim values for the 015 ROM. I did this and everything runs perfectly fine.
-32 79
-8 69
7 59
13 54
20 49
27 45
34 41
41 34
If you calculate it out at 41 degrees C the F temp is 104. Thus the values for the 015 ROM are more useful.
Old May 18, 2009 | 06:12 PM
Appauldd's Avatar
As for your boost limit table....looks like you have an address wrong.
The RPM address needs to be 6dd2.
Old May 18, 2009 | 06:16 PM
Appauldd's Avatar
Your idle temp settings should be....
-32
-8
34
50
77
82
These are more accurate because at 82*C you are at 179*F which is just a little below full operating temperature.
Old May 18, 2009 | 07:01 PM
Ok i think i have it all done i will try to reflash and test drive tonight and see if anything feels funny if anything feels odd i will go back to 0008 and post new info on here
