CA Smog Check
CA Smog Check
Hi, has anyone passed the CA smog test after using ECU Flash? I wasn't certain if ECU Flash could reflash the ECU back to stock in a way undetectable using the scan tools employed during the California smog checks.
Thanks
Thanks
ca testing
all the smog teck should check is if all of the monitors have run and no check engine light is on and if he is a dumb *** and trys bs like you have pending codes tell him to eat sh*& and move on to the next smog shop and good luck to you
Yes I did and had no problems...per the previous post the just look for a check engine light and make sure there are no codes....That said, don't have any obvious modifications or you will likely fail....
Recently had a Evo 10, on E85, tuned via EcuFlash, pass the CA smog with flying colors.
Hay GST what is the going rate on dyno time I need about an hour to reset some fuel and timing on my GTi and use of an external o2 sensor (this is a cis injected dinosor) I am hoping for about 150 to 160 hp PM me if you could thanks
