Oh dear...
Old May 20, 2009 | 01:48 AM
EViR's Avatar
Oh dear...
Well i just downloaded my rom from my evo into ecuflash for the first time.
And well its bad, its afr is ranging from 13.3 to 20.5
Timings all kinds of SCREWD up.
So i downloaded the stock 04 evo basemap from aktive matrix.
If u guys were me. Would u just upload that map into the evo and start fresh? Lol..
Ugh im very worried now.
Old May 20, 2009 | 01:56 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
If you have same ROMID and changed immo, do not worry....
Old May 20, 2009 | 02:08 AM
EViR's Avatar
it kinda just looks like they richend it up ALOT, i think ill have to take a look at that safcii, considering i havnt since i bought the car...
Wonder what its set at n ****... Hmmm will post in the morning!!
(if they made it rich as hell that would explain timeing being all crazified up!)
Old May 20, 2009 | 05:17 AM
Mellon Racing's Avatar
you really haven't given us much to look at and safc II??? don't do that.
Old May 20, 2009 | 06:23 AM
SmurfZilla's Avatar
SAFC is pointless if you are using ECUFlash.
Old May 20, 2009 | 06:48 AM
Appauldd's Avatar
I use the SAFC to monitor idle Hz....works like a champ. Other than that.....its just alight show.
Back on topic....
Just install a base map and start over.
Old May 20, 2009 | 09:00 AM
EViR's Avatar
I never used safc ii it was installed way before i bought the car.
I uploaded the stock 8 rom, started the car and it wont even run, dont even know where to begin on tuning....
So i reuploaded the other map, it has to be tuned a little bit to make my car run.
Where should i start? i dont have evo scan but i have mitsulogger
Old May 20, 2009 | 09:07 AM
sti.this's Avatar
Mistulogger should be fine. First you need to make sure you are using the correct ROMID. Then you need to make sure you copy over your immobilizer to the "stock" rom. Then make sure the safcII is not doing anything to modify the tune. Not that familiar with it, but Id guess you could just unplug it. Then do some logging to see where you are. Report back with logs in hand , and you will get feedback.
Old May 20, 2009 | 09:09 AM
andrewzaragoza's Avatar
what do you mean the afr is from 13.3 to 20.5? is this at idle? can you list down your mods as well. i would suggest taking off your safc first just to make sure that is not causing any problems.
Old May 20, 2009 | 09:20 AM
EViR's Avatar
TBE
AMS Fuel Rail
AMS 780cc Injectors
AMS Intercooler
HKS 272 Cams
My computer wont let me open the csv files cause its gay hmmm.. ill figure something out. Lol, i already unpluged the safcii. If u want i can post the entire rom here and u guys can see for yourself :/ i dunno if im aloud to do that?
Also, im new to this so what is or where is the immobilizer ?? Romid is the id that came OUT of my evo right? Making it to where only my evo will run with that rom. Correct?
Old May 20, 2009 | 02:27 PM
Mattjin's Avatar
If you simply unplugged the SAFC2 then the car will be in Limp Mode. The MAF signal wires need to be rejoined. It will be the Orange and the Pink wires going into the SAFC2.
Old May 20, 2009 | 02:33 PM
kwanza's Avatar
Sounds like maybe you did not copy over the immobilizer code correctly to the new rom. Did you save the original rom that came with the car?
Old May 20, 2009 | 10:29 PM
EViR's Avatar
I sent my rom to a company, and they totaly made it stock from my rom.(Thanks u guys)
So yes now i have the BASE MAP for my evo.
Now my next question is, whats the latency for 780cc injectors? lol..
Someone point me in the right direction atleast
Old May 21, 2009 | 04:23 AM
Appauldd's Avatar
There is a ton of info on injector scaling....searching through it all can be a PITA. Below is the scaling and latencies that work well for me.
Scaling
696
Latencies
3.312
2.04
1.296
0.984
0.792
0.6
0.336
These should get you going in the right direction.
Old May 21, 2009 | 11:40 AM
EViR's Avatar
thanks man Wee lol
