ISCV control system disassembly
Old Dec 15, 2012 | 10:50 PM
  #241
Dynotech Tuning's Avatar
Originally Posted by domyz
48 steps logged. In fact my demand is 18% not 27% (I mixed things in my head). The logged steps aren't related to initial steps.
On the contrary, the logged steps have to do with every single table affecting ISC steps. What is your desired idle ISC steps in the table at the highest coolant temp?
18% would roughly be 41 steps in the IDLE STEPPER TABLE plus 7 steps in the Desired ISC idle table.
Old Dec 15, 2012 | 11:01 PM
  #242
domyz's Avatar
I found that it's best to leave the stepper table linear on the lower demand%.....
so for a demand% value, all the steps will be the same. Idle fluctuation vs coolant temp will be corrected by changing initial steps.
Let's say you're at 27% demand on a startup. Coolant temp is 45 fahrenheit.
So my current stepper lookup table:
So you can conclude that stepper value is Initial steps + 62
Let's say it's idling to 1000RPM
Here is the target idle table:
As you're warming up let's say you reach 68F: You're still at 62 steps, the idle is still 1000RPM. If the stepper table wouldn't have been set for the same steps for a same demand%, Idle would have fluctuated from steps changing without any demand% change, than happened to me while testing.
Let's get back to the warmup sequence. You reach 81F, steps are still at 62 steps + initial steps, but the idle has raised to 1100RPM. If you want to keep the idle on speed, you have to readjust steps without affecting the demand%.
How? by changing the initial steps, you're shifting the opening of the ISCV without affecting actual demand%. It will keep the trims from readjusting the demand%, thus preventing idle speed variation.
So you raise the initial steps at 81F (68 and 93). Next time you'll cross this area warming up, the idle will be closer than what it was, and the demand% won't need to change to keep idle speed. Keep adjusting that until it's very stable for all coolant temps.
Old Dec 15, 2012 | 11:04 PM
  #243
domyz's Avatar
Jamie, I don't see the added initial steps in my logs. Currently my logged steps relate directly to demand% in the lookup table.
Old Dec 15, 2012 | 11:06 PM
  #244
Can you post a pic of you Desired Initial ISCV step position AC OFF-neutral so you show all of the information for what I was asking for?
Old Dec 15, 2012 | 11:09 PM
  #245
domyz's Avatar
I added it up post #242
Old Dec 15, 2012 | 11:16 PM
  #246
MUT 08 definitely works with 9417. You need to exceed 171*F before it will start working and making adjustments. The vehicle has to be in "idle mode" for it to activate though. If TPS% or MAF Airflow HZ are too high, it wont consider itself in idle mode. So with MUT 08 you are still seeing 0% trim?
Old Dec 15, 2012 | 11:21 PM
  #247
domyz's Avatar
Thanks, I still haven't logged the trims so I worked by guessing. For the MUT08, Evoscan had a major bug on my last cold startup, I lost the log. I'll be on this tomorrow on my next startup. It should be right.
Looking at my logs, I definitely see the demand changing drastically at 171 if idle is off target.
... and I'll edit last post accordingly to this. Post still make sense, I just refurbished it
And about logging the steps, for example at some point I definitely log 19.2% demand, 51 steps which is only the main lookup table, not initial steps.
Old Dec 15, 2012 | 11:51 PM
  #248
Trust me, the logged steps are a combination of initial steps+demand%+demand trim.
Old Dec 16, 2012 | 10:11 AM
  #249
domyz's Avatar
I'm sorry Jamie, here logged steps (MUT 16) are ONLY related to the lookup table.
Can you tell me why you say that? Look at my logs, you see that logged steps are what is called in the lookup table only.
Old Dec 16, 2012 | 10:21 AM
  #250
You really need to be logging your MUT08 DEMAND TRIM before you keep on about this. MUT16 is the active ISC Steps with ALL corrections included. Initial steps+demand%+demand TRIM. Have you started logging MUT08 yet?? You can't argue something without all of the data we are conversing about.
Old Dec 16, 2012 | 10:25 AM
  #251
domyz's Avatar
It's stuck at 6.275% for all the warmup sequence until it start to work between 5 and 6% at 175F.
What I think is that the logged demand% (76), is the final demand%. Trims are already added to that number.
What you say wouldn't make sense because at example 45F, initial steps are 89. So you say you'd log 89initial+67lookup+trims? It would have been a too high number and I never logged 100+steps in any situation.
Old Dec 16, 2012 | 10:27 AM
  #252
It would be nice to see all of the data when you have allowed the car to exceed 180*F and settle for 5-10 minutes at idle as well. Not just the warmup.
Old Dec 16, 2012 | 10:37 AM
  #253
domyz's Avatar
Here is my last warmup test log, you can see the thermo fan kicking and turning off one time:
http://www.filedropper.com/evoscandatalog20121216123807
I will try for you to log a warmed up car.
Old Dec 16, 2012 | 10:38 AM
  #254
Add 4-5 steps to your initial steps table and you'll see the DEMAND TRIM value come down.
Old Dec 16, 2012 | 10:39 AM
  #255
domyz's Avatar
Yes that's what I'm doing to correct the demand trims.
