ISCV control system disassembly
Old Jan 24, 2013 | 08:34 PM
  #376
Raptord's Avatar
Groovy, that's exactly the table I need to play with apparently. Can you post the table definition?
Old Jan 24, 2013 | 09:14 PM
  #377
domyz's Avatar
Code:
<table name="ISCV Demand Post Cranking (sub_1F1F8)" category="ISCV Control" address="54f4" type="2D" level="2" scaling="ISCV_AX2_8">
         <table name="Coolant Temp" address="6fde" type="Y Axis" elements="8" scaling="Temp"/>
    </table>
Try this. Again, I'm not sure about the table behavior because it's located in Post WOT demand % routines, but the program branch to it instead of going to Post WOT adder, that's why it could still be the right one....
and it can't harm testing it.
If that's the wrong table I'll go through the code again to search for it with my very little skills
Old Jan 25, 2013 | 05:31 AM
  #378
Raptord's Avatar
Ok, I'll see if I can test it sometime this weekend.
Old Jan 25, 2013 | 09:04 AM
  #379
Dynotech Tuning's Avatar
Originally Posted by domyz
It would be the 3 seconds demand% adder after cranking. Corresponding to "post primer enrichment adder ms" #2 in Jamie's above post.
There should also be a Post-Cranking Enrichment Decay table. I wouldn't be surprised if the decay time was longer during cold coolant temps and shorter at operating temperature. Anything that decays has a timer table somewhere. If you can find it for the Evo 8, that would be helpful. It could either be a 1D table or a 2D table.
-Jamie
Old Jan 26, 2013 | 06:07 AM
  #380
Rather than clutter this thread up, I created a new thread with detailed info on the start-up fuel and ISCV tables. Here is the link:
https://www.evolutionm.net/forums/ec...cv-tables.html
-Jamie
Old Jan 28, 2013 | 05:17 PM
  #381
leecavturbo's Avatar
Originally Posted by catman78
perfect timing jamie,
was rough this morning, tomorrow s/b 10-15 degrees tomorrow am
wife,
what's wrong with your car, why doesn't it start, why don't you get a regular car, blah, bah, blah, yeah, yeah, yeah
lol
Old Jan 29, 2013 | 02:12 PM
  #382
211Ratsbud's Avatar
For some reason now I cannot get my idle above 2000-2200 and it revs up and down and up and down .. I can't figure it out? Is there a cap somewhere I'm missing?
Anyways 2000 ish rpm worth of air flow didn't do much for my boost
Old Mar 11, 2013 | 07:36 AM
  #383
domyz's Avatar
I'm now trying to fix a small issue that I have since a long time. When I accelerate moderately, as soon as the BOV opens when I let go the throttle, I lose all acceleration, making the drivetrain go back and forth a little bit. (synapse, no preload, soft spring, recirc / new engine mount filled with 60A polyurethane). To explain the problem, what is really annoying is not much the back and forth motion of the drivetrain, but more the first bucking motion which makes the passenger slightly go forth in the seat belt if you know what I mean.
Changing my driving habits kinda patched it (letting off the throttle slower and press the clutch as soon as the BOV starts to dump)
I will try to mess with RPM adder table to see if I can add some hang to the car. Also I read that metal intake pipe could mess the MAF reading when recirc. So maybe switching to SD would help.
I'm not aware of any other way to fix that (fuel/timing) ?
I'm pretty some of you already had something similar to fix in the past ?
Old Mar 11, 2013 | 07:39 AM
  #384
Is the BOV fluttering when it opens/closes at light throttle? You are most likely freaking out the airflow through the MAF and the readings are going all over the place.
-Jamie
Old Mar 11, 2013 | 07:43 AM
  #385
domyz's Avatar
-Jamie
No fluttering. The BOV action is very sharp and seems ok. It opens and stays open.
Old Mar 11, 2013 | 07:59 AM
  #386
Is this something new that didn't happen with your old BOV?
-Jamie
Old Mar 11, 2013 | 08:58 AM
  #387
domyz's Avatar
-Jamie
No. I always had engine back and forth movement when I bought the car. It had worn engine mounts on it. (summer 2010)
Problem got worse since I installed the omni map sensor, the grimmspeed BCS, the AEM intake all at the same time and flashed the first v7 rom. (early 2011)
So I changed both front and back engine mounts. Maybe 25% better. (summer 2011)
Last week, I filled a brand new front engine mount with liquid 3m. Maybe 25% better.
Issue is still there a little bit. On the street, I can't really modulate the power on lift-off, as soon as the BOV opens I lose my acceleration. It's kind of hard to drive the car smoothly with that engine braking all at once...
If I lift off until the BOV opens, then I let the throttle at the position where the BOV opened, car acts like that:
arbitrary numbers (tps/acceleration):
30% 0,3 G (lift off starting)
28% 0,25 G
26% 0,20 G
24% 0,15G
24% BOV opens
24% -0,3 G (some bucking + engine movement)
24% -0,2G
24% -0,1G (normal engine braking)
The more I think about it, the more I'm sure it's a MAF reading issue when the BOV's opening. SD should be perfect for me.
If you want to take a look at the tune I'm willing to share it.
edit: And I don't think it'd be a problem for a majority, but I don't have much tolerance for this anymore.
Old Mar 11, 2013 | 09:33 AM
  #388
A simple check would be to disconnect and plug the lines going to the BOV and lightly cruise around and see if the problem disappears with the BOV not opening with vacuum. If it resolves the issue, its definitely from the recirculation.
-Jamie
Old Mar 11, 2013 | 09:46 AM
  #389
domyz's Avatar
Thanks good info. I'll try it and maybe even make it surge a little to see if I still lose acceleration all of a sudden.
Old Apr 3, 2013 | 06:46 PM
  #390
Anubis18's Avatar
Does anyone have the correct addy for ISCV Demand for the Idle Stepper Table Look-up for 9417 V7? I'm trying to convert it from Load to ISCV
