which parameters to log for tuning timing?
Old May 22, 2009 | 11:26 AM
voltexct9a's Avatar
hey guys..
kinda new to this so just double checking to make sure i'm not leaving out anything when i tune for each area..
btw i'm using EvoScan 2.6 beta 11
for timing currently i'm logging
1) throttle
2) rpm
3) knock sum
4) airflow/rev (is this the correct parameter to log to see knock?? seems to only max out at 200)
hope to hear your reply soon!
Old May 22, 2009 | 11:42 AM
gsrboi80's Avatar
TimingAdv is you timing
Old May 22, 2009 | 06:22 PM
Cronic's Avatar
You are on the right track. You might want to take a look at injector duty cycles and get a wideband so you can record real afr's.
Timing adv. is another parameter to log as stated above...
Goodluck
Old May 22, 2009 | 08:18 PM
Resi's Avatar
you will also need to log 1 or 2 byte load
villajer
Cobb AccessPORT
Feb 5, 2017 07:50 PM
xPRimNT
239
Jun 2, 2016 10:40 PM
RS200Z
Jan 12, 2013 06:42 PM
blk-majik
23
Aug 16, 2012 04:20 PM
voltexct9a
12
Jan 9, 2010 11:15 AM
