Patch Request: Improved 2-step control/resolution
Old May 27, 2009 | 09:08 PM
recompile's Avatar
Has anyone looked at the stationary rev limit code to see if its possible to increase the resolution and maybe unlock some parameters ?
How does the factory 2-step work anyway, is it just fuel cut ? If so, could this be changed to spark cut + faster reacting bounces?
Side note: What did we discover max timing retard to be? -15 deg?
Old May 28, 2009 | 08:33 AM
fostytou's Avatar
EvoM Community Team
what do you mean "increase the resolution"?
It is a fuel cut (99% sure), just like the factory rev limiter. It locks right on to whatever RPM I have set, I'm not sure how you could get "faster reacting bounces" other than making more power. I also believe they do fuel cut for a reason, there are a few explanations floating around.
Max timing on a stock ECU should be -10*
Check terphramod v7t (v6 testing thread). It should be out for the IX ecu any time and has a launch map.
Old May 28, 2009 | 04:15 PM
recompile's Avatar
Well if you've ever heard an AEM two step it sounds like the car is about to explode
It's also able to build more boost, seems like it'd be a worthy mod for the stock ECU.
Old May 28, 2009 | 05:39 PM
tephra's Avatar
yeah V7 will have launch maps - which lets you run whatever timing/fuel you want specifically for launching...
that in combination with the stat rev limiiter should provide as much boost as you want... someone just dialed up 20psi on a 35R without too much trouble
Old May 28, 2009 | 09:18 PM
recompile's Avatar
Thanks. Is there a beta for 88590015 v7 ??
Old May 29, 2009 | 10:07 AM
fostytou's Avatar
EvoM Community Team
Not yet, RTF v6testing T?
The "faster reacting bounces" I think you are speaking about are related to the amount of power the car is making at the line, not necessarily the tune/tables (obviously one creates the other, but if the car can't make the power changing the tables all you want won't change anything).
Old May 29, 2009 | 10:57 AM
derekste's Avatar
gear boxes, transfer cases, and rear diffs everywhere are going to hate you for this. I love it!!!
211Ratsbud
Jan 17, 2022 03:01 AM
soeuroithurts
Jul 30, 2016 10:53 PM
justin81
North Texas Evo Club (NTEC)
20
Jan 5, 2012 10:48 AM
BANKS 2
AEM EMS
Dec 10, 2009 01:52 PM
recompile
Evo 'For Sale' Services
Jun 23, 2008 11:01 AM
