Evoscan Logging Problem
Old May 27, 2009 | 10:45 PM
Steveevo9's Avatar
Evoscan Logging Problem with IDC
Hi guy's,
Just recently during logging I was unable to get evoscan to show IDC ......with it ticked before you ask. This is the 1st time as it has always showed on my logging screen.
Any help appreciated.
Cheers Steve
Old May 29, 2009 | 10:10 PM
Steveevo9's Avatar
Hi guy's,
surely someone has experienced something similar, who has a possible solution. I could really use some help.....TIA
Cheers Steve
Old May 29, 2009 | 10:49 PM
mt057's Avatar
If I ever have a problem with evoscan I simply reinstall the program. I hope this helps. Good luck.
Old May 30, 2009 | 05:54 AM
raasfaas's Avatar
make sure you have IPW selected also and it has to be placed above IDC because the function for IDC uses IPW in it so it has to be logged before.
Hope this helps...
Old May 30, 2009 | 07:44 AM
Steveevo9's Avatar
Thanks Fella's
Hi mt057,
Thanks for your advice mate, I did try this but no luck for me however.
Hope this helps...
Hi raasfaas,
I'll recheck my program & give this a once over & I'll also check out my old logs as well. I didn't realise this was necessary........off to check, I hope this is it
Thanks very much mate.
Regards Steve
ps Yep I had somehow put IDC in front of IPW,..........thanks again raasfaas.
Old Jun 1, 2009 | 11:03 PM
raasfaas's Avatar
no prob...good to know you got it working
