Mitsulogger v2.0 Beta 1a Released
Old Jun 2, 2009 | 10:19 AM
  #61
MalibuJack's Avatar
Hopefully the error won't come up any longer and we can then troubleshoot the real issue. I'm willing to say that you'll probably see the same symptoms (too many / too few samples) as you were having with Evoscan though if the problem is driver/os/etc related.
Old Jun 2, 2009 | 10:21 AM
  #62
MalibuJack's Avatar
In the future, anyone with issues with the application *NEEDS* to post on aktivematrix their problem, application feedback, etc.. I don't frequently check EvoM for help requests these days.
Old Jun 2, 2009 | 03:12 PM
  #63
evo_gerard's Avatar
ok well i'm goin to download it and give u some feedback.
Old Jun 2, 2009 | 03:32 PM
  #64
evo_gerard's Avatar
it works!!!!!!!!!!!! in the sence that i'm not gettin any errors. i dont have time to go make a log on the road but i'll do that later. thanks MJ for ur patience!
Old Jun 2, 2009 | 03:43 PM
  #65
MalibuJack's Avatar
Thats a huge improvement and a good sign
Not too bad for being out of the loop for around 2 years.
Old Jun 3, 2009 | 01:43 PM
  #66
fugiwara's Avatar
It works!
It works!! Just did few logs and yes it works!! I want you to look at the logs (1st - 4th pull) to make sure everything looks fine ( what is your email address?
Old Jun 3, 2009 | 07:14 PM
  #67
fugiwara's Avatar
I was just looking at my logs, I have the same problem as I had with evoscan where I don't get enough rpm footprints... it skips 400-500 rpm when TPS is at 100. is it bc I am logging to many things or is it b/c my processor too fast?
Old Jun 3, 2009 | 07:55 PM
  #68
MalibuJack's Avatar
Probably logging too many items.. I would start with only the items you need
I don't recall how many RPM steps there are, but also understand that there is a value of 0-254 that has to represent an RPM of 0-8000 so its going to 'step' especially when the sample rate is also limited due to many samples.
Old Jun 4, 2009 | 04:17 AM
  #69
fugiwara's Avatar
but it only happens under WOT, during normal driving it records rpm normally
Old Jun 4, 2009 | 05:30 PM
  #70
MalibuJack's Avatar
I would look closer at your Laptop and OS install.. What your describing could be either skipping data, or that engine speed is raising faster than the ECU is reporting (I suppose that is possible)
OR, your disk shock protection is suspending disk I/O which can suspend other types of IO.
Now that the error in the application is resolved, your going to have to look closer at your machine as the symptoms are the same for two different applications that work in a similar manner.
Old Jun 4, 2009 | 08:30 PM
  #71
fugiwara's Avatar
The evoscan in my XP based laptop works fine, just vista is skipping data.
suspending disk I/O, what is IO?
should I turn off shock protection?
Old Jun 26, 2009 | 06:37 PM
  #72
Evoryder's Avatar
mitsulogger still doesn't register boost from the zeitronix past 25.5 psi. I am also finding the new version crashes frequently, of course during pulls
Old Jun 27, 2009 | 07:43 PM
  #73
fugiwara's Avatar
could you please answer my questions? thanks.
Old Jun 28, 2009 | 06:08 AM
  #74
MalibuJack's Avatar
Shock protection features are hardware/laptop specific.. if there is a driver installed to handle it, you'll have to figure it out from your laptops manufacturer. On my Lenovo there's a tray icon and a control panel icon for hard disk protection that you could adjust the threshold/sensitivity however that machine has a solid state disk and therefore I disabled the driver and removed the feature altogether, on my Toshiba it had a tray icon only.
On a previous post a user mentioned that the Zeitronix logger stopped at 25psi or so, I realized after release that I never fixed that bug, do you recall if the value went negative? or just pinned at 25psi or so? It was a flaw in the formulas provided.
Old Jun 28, 2009 | 08:06 AM
  #75
Evoryder's Avatar
After 25.5 it goes negative, here is a log to see. I do the following for a correct boost reading: (negative#)+.1+25.5 = Approx psi
Code:
PSI	RPM	actul psi
5.8	3130	5.8
7.4	3218	7.4
9.1	3282	9.1
11.5	3378	11.5
14.5	3459	14.5
17.8	3578	17.8
21.9	3704	21.9
-0.9	3827	26.5
-4	3954	29.6
-4.4	4159	30.0
-4.6	4380	30.2
-4.7	4590	30.3
-5.1	4780	30.7
-4.4	4944	30.0
-3.9	5097	29.9
-3	5284	28.6
-2.7	5460	28.3
-2.4	5647	28.0
-1.8	5789	27.4
-1.5	5938	27.1
-0.8	6063	26.4
-0.5	6227	26.1
25.5	6365	25.5
25.1	6472	25.1
24.6	6621	24.6
24.4	6737	24.4
23.9	6857	23.9
23.6	7024	23.6
23.5	7111	23.5
23.3	7245	23.3
22.9	7291	22.9
I highlighted(in red) the transition point @ 3837rpm, the logs surpass 25.5 and should be approx 26.5psi.
joel794613
Mar 10, 2021 08:47 AM
hoongss
Oct 25, 2011 02:58 PM
evo4mad
Mar 22, 2009 08:38 PM
Stradale
Sep 1, 2008 07:09 AM
b0ostedEV08
May 16, 2006 04:03 AM
