ACD/ABS dash lit flashing
hi all , anyone with ACD/ABS lit flashing with just the cable plug in? it is the 1.3u cable , and has a extra pin compared to the older cables . i have no problem reading data from evoscan but no sure if i should try reflash with te cable . thxs
They will until you get to a particular speed, they'll flash once again when you stop/idle.
You have the option to turn them off in ecuflash mate. Hope this resolves your issue.
.Good luck with the program, it really is a nice bit of kit for tuning & also keeping an eye on things in general.
