88580014 Stuff Required
i am looking for direct boost control tables for 88580014 ROM.
i have been looking for the past week with no luck. any help will be greatly appreciated.
also if there are any others using this map and have some good XML to share feel free.
Thanks
Thanks
so i found the latest 88580013 xml and its the same but no direct boost control tables.... so still looking...
on a side note does direct boost control work with Tephra's V5.10 mod for two boost settings?
ok so just got hold of an 88580013 xml with load based, i guess i can use this for the while.
however, i got this from ecuflash 1.40 where 88580014 references 88580013 in the include line in the xml..
while comparing both roms, most addresses are the same (turbo, lean spool, etc). however the knock sensor filter maps are wrong addresses?
anyone can give some advice here?
rolly, not sure just what info you have, but these addresses work for the 88580013:
knock control - load v rpm : 3cf6
octane update threshold : 3d06
knock multiplier : 6558
knock adder triple gain : 656c
knock adder single gain : 6580
and I dont know if it matches the -14 rom.
Thanks BTW
acsian
Dec 8, 2009 07:13 PM
