Does "baseline WGDC" = "Max Wastegate duty"
Old Jun 6, 2009 | 01:19 PM
INEVOIX's Avatar
I've been doing a ton of reading on controling boost via ECUflash.
Several of the posts state to adjust the "max wastegate Duty".
I have ecuflash version 1.4 and I'm either blind or it doesn't have "max wastegate Duty" in the options under "turbo boost single solenoid"
I do have "baseline WGDC(high gear range)" and "baseline WGDC(low gear range)"
Is this the same as "max wastegate duty"?
This is for an 06 IX
Thanks
Old Jun 6, 2009 | 01:39 PM
jrohner's Avatar
I think it's the same and it's not really supposed to be the max duty cycle. I believe it's supposed to be set to about where the duty cycle should be, it's not the max it can ever go.
Old Jun 6, 2009 | 05:38 PM
tephra's Avatar
yes.
in the old days it was called Max.
but as our understanding grew we changed it to Base ... as it really is a base starting WGDC..
Old Jun 6, 2009 | 05:45 PM
INEVOIX's Avatar
Originally Posted by tephra
yes.
Thank you
Since there is now a "baseline WGDC(high gear range)" and "baseline WGDC(low gear range)", could you explain the difference as far as tuning them for a GM 3 port. I understood when reading about "max WGDC" but now there's 2 of them so Im' not sure where to start....lol From what I saw none of the threads about the GM mentioned these. I may have missed it though
Thanks for any and all help
Old Jun 6, 2009 | 05:50 PM
tephra's Avatar
high/low gear is relatively new too.
basically there is a cross over point which determines if you are in like 1/2/3 or 4/5/6, so you can tune your WGDC's for either high or low.
you *could* change the crossover point so that you have 1/2 and then 3/4/5/6 but that wouldn't be too useful.
OR you can run my tephramod which includes FULL gear control, so a wgdc table per gear basically...
Old Jun 6, 2009 | 05:56 PM
INEVOIX's Avatar
Is that in the new V6? I have V5.10. I'm still learning it though.
I'm trying to read as much as possible before I do it....and wait for my zeitronix WB/map sensor to arrive this week so I can log boost.
D@mn there's a lot to read....lol
Old Jun 6, 2009 | 06:22 PM
tephra's Avatar
yeah v6/v7... so you may not have a rom out yet
Old Jun 6, 2009 | 06:25 PM
INEVOIX's Avatar
I think their still testing it for my ROM: 88590015
Old Jun 6, 2009 | 06:29 PM
tephra's Avatar
V6 is ok to use with 88590015
V7 isn't out yet - waiting for 1 bug to be explored and then I can release more ROM's
Old Jun 6, 2009 | 06:32 PM
INEVOIX's Avatar
D@mn, I can't keep up with you....hahahaha
Thanks for all your help
Old Jun 6, 2009 | 06:42 PM
tephra's Avatar
bar any bug fixes I think V7 will be the last release for CT9A...
It's too hard to do testing for it when I don't have easy access to one
S15me2
Dec 8, 2016 08:22 PM
CDrinkH2O
47
Oct 17, 2012 08:13 PM
smanders
11
Apr 9, 2010 04:34 AM
Raceghost
Sep 14, 2009 05:46 AM
LaXGSR
Jun 8, 2009 12:50 PM
