What happens at peak load?
Old Jun 25, 2009 | 06:12 AM
  #46
raasfaas's Avatar
Originally Posted by burnzy
it would be from your meth i' presume, especially if it's an on/off kit and not progressively tracking your IDCS, even with the HFS-6 I find I have to lean out progressively as the meth comes on, it pretty much lowers AFRs a full point. No way will the afrmap match your afrs with meth as the ecu doesn't track the meth idcs.
Well it's the AEM system so it is progressive, but it doesn't track idc it tracks boost. It starts spraying at a user preset boost level and progressively builds up to full spray by another user preset max boost level. But I think I would have to agree with you, I've been doing some further testing and tuning and it does seem as if its meth related.
The problem I was having with the afrmap was that it wasn't tracking my fuel map (not the actual afr) I dunno if it was an endian issue or what but since I upgraded to the latest version of ecuflash it now tracks fine.
Old Jun 25, 2009 | 06:40 AM
  #47
wreckleford's Avatar
What version of ECUFLash were you using? I would be surprised if it was an ECUFlash issue as the logging is done in EvoScan.
Old Jun 25, 2009 | 07:00 AM
  #48
evo8426's Avatar
...nevermind...someone posted a response similar without me noticing
Old Jun 25, 2009 | 07:52 AM
  #49
raasfaas's Avatar
Originally I was on 1.29a, then switched to 1.35...now I'm on 1.41
I was wondering if it was an endian issue, because in 1.29a (after you brought it to my attention that they weren't coinciding) the endian for afr in my base xml (among a few other items) from the install was set to "big" and all the rest were "little" so I never bothered to change them I just decided to upgrade to a later version which worked...so I just assumed it was an ecuflash issue.
Raceghost
May 21, 2016 12:37 PM
memphis69
Jul 18, 2015 10:10 AM
memphis69
Jul 15, 2015 12:33 AM
Titanium
May 11, 2007 06:34 AM
