Problem with LC-1
Old Jun 24, 2009 | 08:27 PM
Import Junky's Avatar
Problem with LC-1
I'm trying to log my Innovate Wideband and I'm having no luck. I've tried logworks and Evoscan but they have a common problem. It seems as though the computer is not recognizing the serial adaptor or maybe the adapter is broken It's a Belkin Serial/USB Adaptor that I bought a year ago and never got around to using. It has 3 L.E.D.s that are labeled "LINK" "TX" "RX" and with the car running only the "Link" lights up. I have the Stereo Jack hooked up to the OUT and the Terminator hooked to the IN. I've tried to switch these around but still no luck. Here's a screenshot of what I'm seeing.
Excuse the baby in the background
Old Jun 25, 2009 | 06:02 AM
No one has had this problem?
Old Jun 25, 2009 | 06:11 AM
SEEnoEVO's Avatar
LC-1s can be a pain in the *** sometimes. I think i had to go through 3 serial adapters and ended up with one from Radio Shack. I would guess your adapter is the issue.
Old Jun 25, 2009 | 07:35 AM
That blows because that Belkin wasn't cheap. Maybe I'll hook up with one of my IT guys and see if they'll loan me one to try out.
Old Jun 25, 2009 | 07:41 AM
Fast_Freddie's Avatar
Veteran: Navy
Turn the car off, unplug the tactrix and serial to usb, wait a few seconds and plug the serial to usb back in. Open LM programmer and make sure that it is set up for gasoline and close. Open Logworks, start the car and see if it logs now... report back
Old Jun 25, 2009 | 07:48 AM
InjectedPerf's Avatar
our tuner has to go through the same issue here. He went through a bunch of different serial to USB adapters before finding one that will work. When he tunes a UTEC, the only adapter that he could get to work was a Gigaware one, from RadioShack.
Best bet is to just keep trying an adapter until you find one that works. Kinda sucks that they dont put serial ports in most laptops these days. I was told that Dell will add one to your laptop, for a fee, if you request it during the build.
Old Jun 25, 2009 | 07:50 AM
jrohner's Avatar
My LC1 ALWAYS worked great using serial on my old laptop. On my new one, having to use a serial-usb adapter, it is a pain to get it to connect and it usually messes up the calibration and resets my settings by the time I finally get it to connect. I unplug & plug back in both the serial from the usb adapter, and the adapter from my computer multiple times, reboot, and ding around and eventually it connects. It never gives an error message though, it goes into the settings but when I click anything I get that error 'ding' from the speakers of my computer, and settings refuse to change. I'm using the keyspan serial-usb adapter.
Old Jun 25, 2009 | 09:05 AM
Haha.....well none of this is promising . I'll try some of the tips listed above and then I'll try a couple of adapters to see if that helps. Thanks for the replies and if anyone else has suggestions, keep them coming.
Old Jun 25, 2009 | 09:20 AM
Motoxrider7's Avatar
i just wanted to say something. I called innovative acouple weeks ago cuz i had this same problem. They told me Radio shack adapter does not work. I had one and went with a different.
Old Jun 25, 2009 | 09:32 AM
well how did you get tuned by mellon if your adapter is not working with your wideband?
Old Jun 25, 2009 | 12:23 PM
Mellon Racing's Avatar
he drove from ohio to memphis for a road tune and we used my equipment
Import, I just picked up a dynex from best buy that works, it was about 35 bucks though..ouch. www.Evoscan.org is selling a cheaper option that Hamish said will work if I remember correctly.
Old Jun 25, 2009 | 01:36 PM
Thanks Chris. I didn't want to bug you about this so I decided to post this thread. Thanks for the help though. Part of me wants to just run down to the Best Buy and get one for the convenience factor of having it RIGHT NOW! Hopefully it's not something that I'm doing wrong.
NOMIEZVR4
Jan 15, 2015 09:26 AM
parralegend
Feb 18, 2013 02:35 PM
jdm-vr4
Jun 27, 2012 02:33 AM
DCsleeper
Apr 15, 2008 07:05 AM
recompile
Jan 30, 2007 04:28 AM
