evoscan not logging wb02, please help!!
Old Feb 21, 2010 | 08:16 PM
jdm-vr4's Avatar
Hey everyone.
I have a lil situation here... I have Lc-1 wideband and i'm trying to get some logs with evoscan but after selecting external wb02 and the lc-1 wb then making sure that the lc-1 is selected in the wide band section i'm still reading 0 in external and 14's in lc-1. I'm using evoscan 2.6 beta as i have open 2.0 cable and also i'm using serial to usb port. at first the computer gives the usb port 11 or 12 but in the evoscan i can only choose port9 or port1 so i have changed the usb/lc-1 to port1 so the evoscan can read but still no luck.
I have tried logworks and everything works fine but not the evoscan.
Can please somebody help me with my problem?? am i doing something wrong here??
I'm using vista if that makes any difference.
thanks in advance.
marek
Old Feb 22, 2010 | 03:51 AM
veszett's Avatar
Originally Posted by jdm-vr4
Hey everyone.
thanks in advance.
marek
im having a similar problem. my lc-1 works fine in logworks but playing up in evoscan except i get a constant low reading between 3-5. funny thing is it worked fine in evoscan the day before it started playing up.
marek, i dont know if you're trying to run logworks (with the lc-1 connected) at the same time as evoscan but if you are i dont think both programs can use the lc-1 at the same time (same com port). maybe thats why u have 0 reading in evoscan?
Old Feb 22, 2010 | 04:51 AM
colonelfox's Avatar
I've had a similar problem in the past. What I did was go into control panel/system open up the hardware tab and look at device manager. See what com port the LC1 is using in there then make sure that port is available and checked in EVOscan. I know it sounds obvious but I had an issue where the LC1 was using a port that EVOscan did not detect. It ended up being as simple as picking a different USB port. Are you using an RS232 to USB cable? It could also be the drivers for the adaptor. I'm also assuming you have the little end plugged into the input cable on the LC1 right? Mine won't output a signal if it's not plugged in. It could have worked it's way out maybe though thats unlikely. It's a firm fit.
Old Feb 23, 2010 | 06:49 AM
Drill_Sergeant's Avatar
Veteran: Army
also make sure your terminator plug is completely plugged into the IN wire
Old Feb 23, 2010 | 07:09 AM
nothere's Avatar
sorry, didn't see you were using the open 2, so don't know what to say.
if it were the regular cable this would work...
just checking the external wb and making sure you have a port should do it.
do not check the lc-1 box.
Old Feb 23, 2010 | 07:35 PM
jdm-vr4's Avatar
so i went through all the connections again and as soon as i plug the RS232 to USB in my computer it recognise it as the right cable in com11. then i'd go to evoscan and to the wide band menu o try and select com11 for my wideband but evoscan doesnt diplay that com number so the only numbers i can select is com1 and com9 sometimes others will come. so for that i change my initial com11 for my cable to com1 so i can have the evoscan checked of as the same port.
now my connector is pluged in to the "in" cable from the lc-1 but i'm still unable to get this stupid evoscan to read my wideband.
I have tried logging with logworks and its all fine. everything else in evoscan is logging correctly but not the wb02.
have you guys got any more ideas???
Old Feb 23, 2010 | 11:00 PM
veszett's Avatar
mate, the terminator plug goes into the "IN". the connector that goes to ur lappy should be plugged into the "OUT" on the LC1.
having said that does anyone know why my LC1 is only giving me a value between 3-5 in evoscan but a perfect reading in logworks? https://www.evolutionm.net/forums/ge...rial-port.html
Old Feb 24, 2010 | 12:14 AM
jdm-vr4's Avatar
sorry guys i meant lc-1 is in ''out'' and the little plug is in ''in''
Thanks
Old Feb 24, 2010 | 05:57 AM
Veteran: Army
so is it working properly in LogWorks?
Old Feb 24, 2010 | 12:23 PM
sw20's Avatar
Try with a different uSB-serial cable, I had the issue before too, at the end, you have to get to bestbuy and get the belkin one... or something good, it didn't work with my $10 USB-serial cable.
Old Feb 25, 2010 | 12:22 AM
jdm-vr4's Avatar
ok i got it to work guys, all i did is un ticked everything in evo scan and only left the external wb ticked and it worked! Then just ticked all the items back that i needed and it still worked so really happy now as my tune can be sorted. Thanks heaps for all your input guys.
Old Feb 25, 2010 | 08:35 PM
LGshow19's Avatar
Problem solved!!!
Old Jun 27, 2012 | 02:33 AM
veegeeta's Avatar
hi iam having a simaliar problem, I use a taxtrix 2.0 and having trouble geting a reading through evoscan im using a lm-2 serial 2.5mm patch cable, I get a reading of 0 and it says com port 1 does not exist ( I should be able to plug my mtx-l gauge kit into my tax trix cable with this sterio cable to get my readings trough evoscan)
Ive now got this all sorted.
mrm95
11
Sep 7, 2015 06:40 PM
NOMIEZVR4
Jan 15, 2015 09:26 AM
stunt2
Apr 12, 2011 06:47 PM
evo9_jdm
May 7, 2010 09:04 AM
TouringBubble
Jun 22, 2009 11:07 AM
